Verifying Answers to a Problem Using Attached Figure
  • Thread starter Thread starter discoverer02
    Figure
The discussion revolves around an RL circuit problem involving a switch that is closed before t=0 and opened at t=0. The original poster seeks to verify their answers regarding the initial voltage across an inductor and the time it takes for the current in a resistor to reach a specific value after the switch is opened.
  • The original poster attempts to apply Kirchhoff's loop rule to determine currents at steady state and analyze the circuit after the switch is opened. They express uncertainty about their method and the correctness of their answers, particularly for part c).
Some participants have noted confusion regarding the attached figure and the original poster's calculations. The original poster acknowledges errors in their posting and clarifies their understanding of the circuit behavior after the switch is opened. There is an ongoing exploration of the reasoning behind the differing answers.
The original poster mentions a correction to the emf value in the diagram and reflects on their understanding of current behavior in the circuit after the switch is opened. There is an indication of a potential misunderstanding regarding the immediate change in current.
discoverer02
I want to check my answers for this problem: Part c) below doesn't agree with the book. And even though part a) agrees, I'm not sure about my method.
I've attached a figure for reference.
For the attached figure, the switch is closed fo t<0, and steady-state conditions are established. The switch is thrown open at t = 0.
a) Find the initial voltage across L just after t = 0. Which end of the coil is at higher potential: A or B?
c) How long after t = 0 does the current in the 6kOhm resistor have the value 2.00 mA.
For part a), I used Kirchhoff's loop rule to get the currents at steady state.
6kOhmI1 = 18V
I1 = 3mA
2kOhmI2 - 0.4H(di2/dt) = 18V ==> di2/dt = 0 at steady state.
I2 = 9ma
Itotal = 12mA
Once the switch is thrown open I have an RL series circuit.
In a series circuit I should be the same across both resistors so:
I1 goes to zero, so I total in the circuit is 9mA.
6kOhmI + 2kOhmI - 0.4H(di/dt) = 0
0.4(di/dt) = 8kOhmI = 8kOhm(9mA) = 72Volts; B has the higher potential.
If my reasoning above is correct then for part c)
I = Iinitial(e^(-t/T)) where T = L/R = .4/8000 = 50 microseconds
2mA = 9mA(e^(-t/50us)
ln(1/6) = -t/50us
t = 50ln(1/6) = 75.2 microseconds. The answer is the book is 75.2us
Thanks in advance for the help.
Hmmmmmm? 24 hrs and no response. No ideas or suggestions on why the answer for the second part is different than what I came up with?
Wrong picture. Can't tell what you're talking about. :smile:
Sorry about that.
I made some errors in my posting. The diagram should show the emf as 18V. There was also a multiplication error that I corrected.
What had me confused is that the current in the loop on the left goes to zero after the switch is opened. I was thinking (or wasn't thinking) that it did not immediately go to zero.
Anyway I see now that it does, so the only current in the right side loop is 9mA and everything works out.
Thanks.
I'll take more care in the future when posting my questions.
  • · Replies 31 ·
  • · Replies 28 ·
  • · Replies 16 ·
