Nuclear Waste from Reactors: Dangers & Uses
  • Thread starter Thread starter DeathKnight
    Nuclear
The discussion revolves around the potential uses and dangers of nuclear waste generated from nuclear reactors. Participants explore whether this waste can be repurposed for nuclear weapons, the implications of geological disposal, and the perceived hazards associated with nuclear waste. The conversation includes theoretical, technical, and conceptual aspects of nuclear waste management and its implications for safety and energy production.
  • Some participants suggest that while nuclear waste can theoretically be used to create nuclear weapons, it is difficult to do so with "reactor-grade" plutonium, which requires specific reactor designs to prevent weaponization.
  • Others argue that nuclear waste could be utilized in "dirty" bombs, which disperse radioactive materials using conventional explosives.
  • There is a proposal for recycling actinides from nuclear waste to reduce long-lived radioactive materials, with some participants advocating for the use of mixed oxide (MOX) fuel.
  • Transmutation is mentioned as a potential method for dealing with long-lived radioactive waste, with some participants expressing interest in its feasibility and energy production potential.
  • Concerns are raised regarding the historical context of nuclear waste reprocessing in the U.S., particularly the impact of the Carter administration's policies on current practices.
  • Some participants note that other countries continue to reprocess nuclear waste, raising questions about the effectiveness of U.S. policies in this area.
Participants express a mix of viewpoints, with no clear consensus on the best approach to nuclear waste management. Disagreements exist regarding the feasibility of using nuclear waste for weapons, the safety of geological disposal, and the effectiveness of current policies on reprocessing.
Limitations include the complexity of nuclear waste management, the varying definitions of "weapons-grade" plutonium, and the unresolved technical and political challenges surrounding reprocessing and transmutation.
DeathKnight
Can the nuclear waste from nuclear reactors be used to make nuclear weapons?
Secondly, Whats wrong in burying nuclear waste deep inside the Earth or beneath the oceans? And lastly, are the hazards of nuclear waste from nuclear reactors exaggerated?
Any help will be appriciated.:smile:
DeathKnight,
In answer to your first question - it depends.
The plutonium that is used in nuclear weapons is produced in nuclear reactors - called
production reactors. However, those reactors are operated in a particular manner so
that one gets the proper mixture of plutonium isotopes for bomb fuel; which is called
"weapons-grade" plutonium.
The DOE has released the fact that so-called "reactor grade" plutonium can be used
to make a nuclear weapon - but it's difficult to do. A novice nuclear weapons designer
would have trouble making a weapon from "reactor-grade" plutonium; whereas an
experienced nuclear weapons designer knows how to do it.
If one designs the reactor properly, one can even prevent the experienced designer
from using plutonium from such a reactor. For example, the IFR reactor designed
by Argonne National Lab:
http://www.pbs.org/wgbh/pages/frontline/shows/reaction/interviews/till.html
As Dr. Till discusses, it is IMPOSSIBLE to use the waste from the IFR to make
into weapons. The IFR's plutonium recycle process doesn't produce the pure
plutonium needed for weapons.
Geological disposal - burying the waste, as you say - is what the National Academy
of Sciences suggested in the late 1950's. There's been a lot of work on Yucca
Mountain - but it is still a political hot potato.
I believe we should do what the IFR does - recycle the "actinides" - i.e. plutonium and
the other heavy isotopes back to the reactor as fuel. This can also be done by
taking our current nuclear waste - chemically separating out the actinides - then
blend that with fresh uranium fuel to form what is called "MOX" - "mixed oxide" fuel.
[ The fuel is a mix of uranium oxide, plutionium oxide...]
If one does that - then the waste that needs to be disposed of consists merely of the
fission products - as Dr. Till and interviewr Richard Rhodes [ Pultizer Prize wiiner ]
discuss in the Frontline interview above.
If all you have is fission products - the longest lived fission product of any consequence
is Cesium-137. Cs-137 has a half-life of about 30 years. In about 20 half-lives, or
600 years; the radioactivity of the nuclear waste will be less than the radioactivity
of the uranium that was originally dug out of the ground.
So from 600 years on - the waste repository would pose less of a threat to humanity
and the environment, than the uranium that is already sitting UN-MINED in the crust
of the Earth. If the waste consisted of only fission products - the longevity of the
waste is lessened.
The EPA had originally promulgated regulations that regulated the performance fo the
repository for 10,000 years. Recently, the U.S. Supreme Court struck down that limit
and said EPA had to regulate for 250,000 years.
I think some want the regulation to continue until every last radioactive atom has
decayed to a stable state.
Dr. Gregory Greenman
Physicist
Although it is very difficult to make nuclear weapons from waste, the waste could easily be used to make "dirty" bombs. These are bombs based on conventional explosives packed with nuclear waste to create a radioactive cloud when detonated.
In answer to your first question - yes. That's exactly what the North Koreans did.
Ah, not quite.
North Korea did not use nuclear waste (fission products). Rather they did what other nations possessing nuclear weapons did, they reprocessed the fuel, separating the waste (fission products) from the useful fissile Pu-239/Pu-240. The Pu-239/240 is then fabricated into metal spheres (pits) for implosive nuclear warhead. The alternative process is to use centrifuges to produced highly enriched U (U-235), which is not as effective as Pu-239.
The waste (fission products) is radioactive, but cannot fission. As mathman correctly indicated, the waste could be used in a 'dirty' bomb in which conventional explosive are use to disperse radioactive waste over a wide area.
I was just reading about transmutation. From what I have read, it seems like a very good way to deal with the long-lived radioactive waste. I've also read that during this process energy is released which can be used to produce electricity. If that's true why not US or other countries transmutaing their radioactive waste?
I believe transmutation has been demonstrated in the laboratory on a very small scale. It takes are large system in order to do it economically, and that would take several years of development.
http://apt.lanl.gov/atw/
http://www.pnl.gov/atw/ReportToCongress/index2.html
and alternative to transmutation by accelerator - http://www.world-nuclear.org/sym/2001/venneri.htm ( www.world-nuclear.org/sym/2001/pdfs/venneri.pdf )
The Modular Helium Reactor has yet to be developed and built.
http://www.cem.msu.edu/~cem181h/projects/98/nuclear/ - a reasonable overview of the situation.
Transmutation of transuranic elements also requires partitioning or separation, which is accomplished in a reprocessing facility.
http://www.ocrwm.doe.gov/ymp/about/reprocess.shtml
The US has not reprocessed commercial fuel, nor defense fuel IIRC, in many years. Reprocessing was halted during the Carter administration (ca. 1977) out of concerns for proliferation or diversion of Pu-239 to weapons. Reprocessing appears to back on the table as an option in the fuel cycle.
Then there are those who oppose the transmutation option - http://www.ieer.org/reports/transm/pressrel.html
http://www.greenscissors.org/energy/atw.htm
Astronuc,
It should be back on the table - Carter's policy didn't work.
The USA wanted the United Kingdom, France, Japan... to stop reprocessing
nuclear fuel. The USA really wasn't concerned about US reprocessed waste
finding its way into a bomb program - the concern was for foreign powers.
The Carter Administration felt that it could not ask these other nations to
forego waste reprocessing, if the USA still did waste reprocessing. So
nuclear waste reprocessing / recycling was halted in the USA.
The problem is that these other nations did NOT follow the USA's lead.
The United Kingdom has continued reprocessing at its facilites at
Sellafield along the Cumberland Coast ever since the USA's self-imposed
ban. Likewise, for France; which has continued reprocessing at their
facilities at La Hague.
Japan has had either the UK or the French reprocess its waste - until
fairly recently when it started its own reprocessing plant.
So the whole reason for foregoing the advantages of reprocessing for the
USA, was so these other powers would stop. It's been nearly 3 decades,
and they haven't stopped. So we should just declare that this self-imposed
ban was a failure - since it did accomplish its stated goals - and begin
reprocessing again.
Physicist
Morbius,
We have some catching up and relearning to do.
Also, something of personal interest to you, I had a rather brief and interesting discussion about IFR recently. :wink: It may be back on the table as well. It will be interesting to see where that goes!
Astronuc.
  • · Replies 19 ·
  • · Replies 29 ·
  • · Replies 18 ·
  • · Replies 43 ·
9K
