What Is the Proper Sign Convention for a Virtual Image in Lens Calculations?
  • Thread starter Thread starter ACLerok
    Lens Light
The discussion revolves around a problem involving a converging lens with a focal length of 12.0 cm that forms a virtual image. The original poster attempts to determine the position of the object based on the lens equation, but encounters confusion regarding the sign convention for virtual images.
  • Participants discuss the application of the lens equation and the implications of sign conventions for the object and image distances. There is a focus on the conditions necessary for a converging lens to produce a virtual image.
Some participants have pointed out potential sign mistakes in the original poster's calculations. There is an ongoing exploration of the correct placement of the object relative to the lens and the focal point, with multiple interpretations of the sign conventions being considered.
Participants are navigating different sign conventions and their implications for the calculations, which may lead to confusion in determining the correct object distance. The original poster's calculations have been challenged based on these conventions.
ACLerok
Here is the problem:
A converging lens with a focal length of 12.0 cm forms a virtual image 8.00 mm tall, 17.0 cm to the right of the lens.
I am supposed to find the position of the object. I tried using the lens eq. 1/s + 1/s' = 1/f where s is the distance of the object from the lens, s' is the dist of the image from the lens, and f is the focal point. I got s to be 40.82 cm but I'm being told it's wrong. Is there something I am missing here? Any tips and points would be great.
Thanks!
Careful with the signs!
For a converging lens, where must an object be for a virtual image to be produced.
Regards,
George
to the right of the lens correct? does this change the equation in some way? :confused:
And where with respect to the focal point?
George
Well my obvious guess would just be (s' - f) centimeters to the right of the focal point.. :confused:
In order for a converging lens to produce a virtual image, the object must be between the focal point and then lens. I have been trying to get you to see that your answer of 40.8 cm can't be correct. I am reasonably certain that you have made a sign mistake, but I used a different sign convention (and thus different formulae) last semster, and I can't remember, off the top of my head, the other sign convention, so I'm not quite sure where you're going wrong.
When I use the convention with which I am familiar, I can:
1) get an answer that is between the focal point and the lens;
2) get 40.8 cm when I make a sign mistake.
Regards,
George
Thanks!
What sign did you use for f and for s'? That`s your mistake. f is positive for a converging lens. What is the sign for s' for a *virtual* image?
Pat
10K
