| Thread Closed |
Ferrari VVT |
Share Thread | Thread Tools |
| Feb5-06, 01:10 PM | #1 |
Ferrari VVT
Why isn't Ferrari Variable valve timing - they have a 3d cam with variable profile along its length and shift the camshaft to provide variable valve timing, why isn't it popular?
Is it because of the cost? |
| Feb5-06, 02:03 PM | #2 |
Yeah, it's not an easy thing to do cheaply. I would imagine there are some pretty major wear and reliability issues which would you would need to overcam (sorry) to make it viable for mass production. Most cars aren't Ferraris, and if any power uprates (or rather, tuning the torque and power curves) are needed then they're generally much easier to achieve by alternative means.
It's still a nice touch though! |
| Feb5-06, 02:21 PM | #3 |
Various other variable valve-timing implementations are relatively popular. Honda has VTEC, present on quite a number of its production models, while Toyota has VVTL-i. These systems aren't true "3D" cams, but rather cams with two sets of lobes, providing two different valve timings for low- and high-rpm operation. They are relatively fail-safe: if the cam's solenoid fails to operate, you're just stuck with the low-end cam until you get it fixed.
- Warren |
| Feb6-06, 01:09 PM | #4 |
Ferrari VVT
I don't know whether or not any are in commercial production, but there are also hydraulic and/or solenoid operated valves that eliminate the cam entirely and can be infintely varied by on-board computer control. That sidesteps any wear issues.
| Feb6-06, 03:44 PM | #5 |
One variant (and I'm not sure whether Lotus toyed with this for a while, it's potentially on a current Toyota engine, anyone?) is to use a secondary mechanism to hold the valves open after the nose of the cam lobe has started to fall.
| Feb7-06, 01:07 AM | #6 |
1. High power consumption = high power alternator = high cost 2. valve seating velocities 3. plain expensive |
| Feb7-06, 01:09 AM | #7 |
BTW, how much approxiamately does a camshaft with cams cost?
| Feb7-06, 10:37 AM | #8 |
There should be some method available to dampen the final closing speed, such as tiny hydraulic shock absorbers (which is a built-in function of the hydraulically-activated valve system). Expensive, yes... but I'd expect that the cost could be kept within the same sort of range as selective cylinder deactivation, which is quite common nowadays. As for the price of a cam and lifters, I couldn't begin to tell you. For one thing, prices are different here than in the US or Europe. Also, the last time that I bought one was 26 years ago. That was a Crane unit, and it cost $120. |
| Feb7-06, 12:29 PM | #9 |
A camshaft with cams, as opposed to one without?!
![]() I could buy a brand new performance camshaft for my Ford engine for about £120, but recently bought one at work which was about £4500. |
| Feb7-06, 01:00 PM | #10 |
| Feb7-06, 01:03 PM | #11 |
Well, it would definitely make the things much cheaper to machine and grind! |
| Feb7-06, 01:15 PM | #12 |
Not to mention cutting down on lifter wear and valve spring fatigue.
| Feb7-06, 01:44 PM | #13 |
Valve seat wear would definitely be improved. Have a funny feeling that fuel consumption and emissions would be down quite a lot too. |
| Feb7-06, 05:21 PM | #14 |
Along with horsepower.
| Feb8-06, 03:36 AM | #15 |
Thank you for the responses.
Then again, hydraulic systems are more complex. I don't think cylinder deactivations are done on a cycle to cycle basis. Therefore they are easier to implement. |
| Feb8-06, 03:38 AM | #16 |
Seriously, what was so special about it? Was it handmade or something? |
| Feb8-06, 07:07 AM | #17 |
Recognitions:
This information is rather old (~10 years), but Lotus was designing an active valvetrain at one point. Apparently, the electrohydraulic actuators cost about US$1000, and couldn't even manage much more than 4-5000 rpm. That's $1000 per valve!
I'm sure things have improved since, but it's probably still too difficult to get cheap reliable systems to work at reasonable redlines. Maybe this could be partially worked around by first applying the technology to diesels or other engines that operate at lower speeds. Then it could be advertised as an improvement in fuel economy rather than performance. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Ferrari VVT
| And he crashes a 1.5 million dollar Ferrari... | General Discussion | 21 | ||
