Calculating Forces & Friction to Stop a Car
  • Thread starter Thread starter Xenocite
    Forces Friction
The discussion revolves around calculating the minimum stopping distance of a car traveling at a specific speed on a flat road, considering the effects of friction. The problem involves concepts from dynamics and frictional forces.
  • The original poster attempts to determine the stopping distance by considering the car's weight to find the normal force and subsequently the frictional force. Some participants question whether the mass of the car is necessary for the calculations, suggesting alternative approaches to derive acceleration from friction without it.
Participants are exploring different interpretations of the problem, particularly regarding the necessity of the car's mass in calculating the frictional force. Some guidance has been offered on how to relate frictional force and acceleration, indicating a productive direction in the discussion.
The original poster expresses uncertainty about missing aspects of the problem and seeks hints, indicating a desire for clarification on the relationship between mass, normal force, and friction.
Xenocite
Maybe I'm thinking way too deep for this problem, but here goes:
-A car is traveling 11.7 m/s on a flat road.
-Acceleration of gravity = 9.8 m/s^2
-The coefficient of friction between the road and the tires is 0.156
-What is the minimum distance in which the car will stop?
I tried to start this problem, but I really need to know the car's weight to figure out the normal force (Fn - force exert on the car by the road). The car's weight will also give me the horizontal force, which I could use it to find the car's deceleration. Then find the time period from start to stop to find the distance it travelled. Is there another aspect of this problem that I fail to notice? Any hints would help. :confused:
you don't need the mass of the car to proceed
what is the formula for any force on an object of mass m
what is the force of friction on thisc ar... from this can you calculate the acceleration due to this firction?
Well, to my current knowledge, the frictional force requires the mass of the car to be calculated:
frictional force = coefficient of friction * mass
Sorry if I'm not getting anywhere by your input.. I'm really trying here :(
firctional force = coefficient x (NORMAL force)
here since the car is on a flat surface... the normal force is equal to the force of gravity (that is not always the case, however)
also you can write ANY force as mass x acceleration
so u could write firctional force as mass x acceleration.
now you already know an expression for frictional force which you can equate to mass x acceleration... the mass will cancel out.. and you are left with the acceleration
22K
