Solving Infinite Sums: Where to Begin?
  • Thread starter Thread starter eep
    Infinite
The discussion revolves around evaluating infinite sums, specifically the sum of the reciprocals of the squares of odd integers. Participants express confusion about how to approach infinite summations and seek resources for better understanding.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore various methods for summing infinite series, including the use of Fourier series and numerical estimation techniques. Questions arise regarding the validity of certain approaches and the definitions of series coefficients.
There is an ongoing exploration of different methods to evaluate the infinite sum, with some participants offering insights into Fourier series and numerical estimation. However, there is no explicit consensus on the correct approach or final value of the sum.
Some participants reference specific coursework, indicating that the problem may be part of a larger context involving quantum mechanics and Fourier analysis. There are also mentions of discrepancies in textbook solutions and the need for clarity on series definitions.
eep
I'm having a lot of trouble with infinite summations. For example, I need to sum the following quantity:
[tex]\sum_{n=1,3,5...}^{\infty}\frac{1}{n^2}[/tex]
I tried to find the result on the internet but to no avail. I really have no idea where to begin when evaluating infinite sums, so if someone could please recommend a good book or point me to a good resource, I'd greatly appreciate it.
Observe that:
[tex]\sum _{n\ odd} \frac{1}{n^2} = \left(\sum _{n \in \mathbb{N}}\frac{1}{n^2}\right) - \left(\sum _{n\ even}\frac{1}{n^2}\right)[/tex]
[tex]= \left(\sum _{n \in \mathbb{N}}\frac{1}{n^2}\right) - \left(\sum _{n = 2,4,6,\dots}^{\infty}\frac{1}{n^2}\right)[/tex]
[tex]= \left(\sum _{n \in \mathbb{N}}\frac{1}{n^2}\right) - \left(\sum _{m = 1,2,3,\dots}^{\infty}\frac{1}{(2m)^2}\right)[/tex]
[tex]= \left(\sum _{n \in \mathbb{N}}\frac{1}{n^2}\right) - \left[\frac{1}{4}\left(\sum _{m = 1,2,3,\dots}^{\infty}\frac{1}{m^2}\right)\right][/tex]
[tex]= \frac{3}{4}\left(\sum _{n \in \mathbb{N}}\frac{1}{n^2}\right)[/tex]
I'm not sure what that sum is. We all learn that it converges, I don't recall if we ever learn how to compute it. It's 1.6 something or 1.5 something.
In the context of which class is this question asked? If you're allowed to use Fourier series, than it can be done. Otherwise, I don't recall of a way either.
Fourier series would be fair game, I suppose. This is from a Griffiths' Quantum Mechanics problem in which given [itex]\psi(x,0)[/itex] you're supposed to find [itex]\psi(x,t)[/itex] using Fourier series. The problem then asks me for the expected energy, which left me with the infinite sum from above.
K, then here's a way:
Develop the function f(x) = x defined on [0,pi] in a serie of cosines (i.e. consider f as a mere restriction of an even function f*, and expand f* in a Fourier serie as you normally would)
The serie will be summed over odd integers and 0 only and the coefficients of that serie will be a_0 = 1 and a_n = -4/(pi² n²). Now set x = 0. All the cos(nx) terms become 1 and you can solve for
And also find
[tex]\sum_{n \in \mathbb{N}}^{\infty}\frac{1}{n^2}[/tex]
following AKG'S procedure if you desire.
Funny how the odd part of the serie makes for a whooping 3/4 of its sum and the even part only 1/4.
I find
[tex]\sum_{n=1,3,5...}^{\infty}\frac{1}{n^2} = \frac{\pi^2}{4} \Rightarrow \sum_{n \in \mathbb{N}}^{\infty}\frac{1}{n^2} = \frac{\pi^2}{3}[/tex]
But this does not seem right, as after 17 terms, it can be established that the 2 first digits of the sum are 1.5 < pi²/3 :(
Eeh?
[tex]\sum_{n=1}^{\infty}\frac{1}{n^{2}}=\frac{\pi^{2}}{6}[/tex]
A friend of mine had a novel way of doing these -- get a numerical estimate, and then try multiplying or dividing the results by appropriate powers of pi. (He had ways of telling which powers were good) When you get one that looks like a rational number, you have good odds that's your sum!
arildno said:
Eeh?
Well indeed, but can you see the flaw in my reasoning? The values a_0 = 1 and a_n = -4/(pi² n²) are taken straight from the solution manual of my analysis textbook.
Hurkyl, how would that work exactly? Given your initial guess, you're going to change it by at least a factor of [itex]\pi[/itex]. This method is only good if your initial guess is thus off by at least a factor of [itex]\pi[/itex], i.e. your initial guess has to be way off. Am I missing something?
You add up the first two terms of your sum and get, say, 1.6448. You suspect there's a pi^2 factor, because it's a sum of inverse squares, so you divide by pi^2 leaving 0.16665. That smells like 1/6, so you decree that the sum is pi^2 / 6.
I see. I tried it with 1/n³, and summing the first 10 terms gives 1.197532... Dividing by [itex]\pi ^3[/itex] gives 0.03862... which is 1/25.89182... As more terms are added, the estimate will increase, so the result of dividing by [itex]\pi ^3[/itex] will increase so expressing it in the form 1/x will make the x decrease. So if anything, the 25.89182... will have to decrease to 25, which seems to drastic a drop. Maybe it's not [itex]\pi ^3/x[/itex] but [itex]y\pi ^3/x[/itex] where y and x are co-prime, y is not 1. Or it may not be [itex]\pi ^3[/itex] at all. However, I tried it with a few other powers (1st, 2nd, 4th, and 6th) and none of them give anything that looks like 1/x in the end, for some integer x (i.e. the x that comes out is far away from an integer).
I tried it with [itex]1/n^4[/itex], and dividing by [itex]\pi ^4[/itex] it seems that maybe the answer should be:
[tex]\frac{\pi ^4}{90}[/tex]
Does anyone know if this is right? Or even better, does anyone know an online resource where the values of various sums are given?
It helps to know that zeta(p) is of the form pi^p/something only if p is even. That way you know the trick of your friend will only work for p even. That would explain your problem with zeta(3) AKG. But I like the trick too. It can be useful in an exam.
Thanks Hurkyl.
Not really, the odd terms contain 1, which is distinctly larger than any of the other entries, and takes up a signficant part of pi^2/6 on its own (about 2/3 of it). Correspondingly the odd terms will be even more significant if we were to look at other higher (lower) powers of 1/n (n)
Check how your text defines the Fourier series and coefficients. There's probably a 1/2 term in front of the a_0 term in the series.
Ah! Yes, I had forgotten about that! =)
