How does the orbital diameter of 2003 UB313 compare to its orbital period?
The orbital diameter of 2003 UB313, also known as Eris, is significantly larger than that of Pluto, with a semi-major axis of 67.7 AU compared to Pluto's 39.5 AU. According to Kepler's law, the relationship between orbital period and radius is defined by the equation T²/R³. This results in an orbital period for UB313 of approximately 558 years, which is 2.25 times longer than Pluto's 248-year period. The elongated orbit of UB313 takes it up to 97 times farther from the Sun than Earth, emphasizing its distant position in the solar system.
  • Understanding of Kepler's laws of planetary motion
  • Familiarity with astronomical units (AU)
  • Basic knowledge of orbital mechanics
  • Ability to perform square root calculations
  • Research Kepler's Third Law of Planetary Motion in detail
  • Explore the characteristics of Eris and its orbital dynamics
  • Study the differences between the orbits of dwarf planets in the Kuiper Belt
  • Learn about the methods used to calculate orbital periods of celestial bodies
Astronomers, astrophysicists, and students of planetary science will benefit from this discussion, particularly those interested in the dynamics of distant celestial bodies and the application of Kepler's laws.
DaveC426913
2025 Award
Is this true?
(excerpted from http://www.astro.uni-bonn.de/~bertoldi/ub313/" about 2003 UB313)
"...Its very elongated orbit takes it up to 97 times farther from the Sun than is the Earth - almost twice as far as the most distant point of Pluto's orbit – so that it takes twice as long as Pluto to go around the Sun..."
Is there a direct correlation between orbital diameter and orbital period? I would have thought it would be logarthmic.
Astronomy news on Phys.org
DaveC426913 said:
Is this true?
Is there a direct correlation between orbital diameter and orbital period? .
Yes there is...
but they've made very rough verbal approximations.
Actually to make orbital period determinations you must use the semi-major axis of the orbit.
In this case the semi- major axis of UB313 is 67.7 AU compared to Pluto's 39.5 AU. So it is really only 1.7 times as distant as Pluto.
The orbital period vs. orbital radius (s-m axis) scales as T^2/R^3, (Kepler's law).
So the period T = sq.rt.(1.7)^3 = 2.25, meaning its orbital period is 2.25 times that of Pluto.
Since Pluto's orbital period is 248 yrs, then the orbital period of UB313 is about 558 yrs. -- Approximately since all my figures are truncated.
Creator:biggrin:
9K
  • · Replies 21 ·
11K
