Sound wave relative minima help
The problem involves two speakers emitting sound waves at a frequency of 800 Hz, positioned 1.25 m apart. The task is to locate points along the line between the speakers where relative minima in sound intensity are expected, given the speed of sound as 343 m/s.
  • Participants discuss the relationship between wavelength and the conditions for minima, questioning how to determine the relevant parts of the wavelength. Some suggest visualizing the wave interference and considering the midpoint between the speakers.
The discussion is ongoing, with participants exploring different aspects of wave interference and the conditions for minima. Some guidance has been offered regarding the relationship between path difference and minima, but there is no explicit consensus on the approach to solving the problem.
There appears to be some confusion regarding the conditions for maxima versus minima, and participants are encouraged to clarify the problem's requirements without introducing irrelevant information.
jesuslovesu
Two speakers are drive by a common oscillator at 800 Hz and face each other a distance of 1.25 m. Locate the points along a line joining the two speakers where relative minima would be expected (v =343m/s speed of sound)
How would I do this? I think I would just take part of the wavelength but how do you know which parts?
Consider the problem visually, as though you could see the waves (picture transverse waves). How long are the wavelengths? And what would you expect to happen at the exact midpoint between the speakers?(At this point the waves from the two sources have traveled exactly the same distance to get to the point, so what kind of interference?)
maxima will be observed at all the points where the path difference between the waves is zeo . the perpendicular bisector of the 2 sources will be the locus of the points where maximum sound is observed .
First, the question is about *minima*. Second, maxima occur when the path difference is zero or any multiple of the wavelength. Third, the question is about point along the line joining the two sources!
Please read carefully the question...it can only confuse the person asking if you provide irrelevant information.
Do you know the condition for minima? If two waves are emitted in phase and are of the same wavelength, there will be minima if the difference of the distance traveled is lambda/2 or 2 lambda/2 etc...
That`s the first step to understanding the problem...
  • · Replies 19 ·
  • · Replies 27 ·
