Using Galvanometer of 90 Ohms Resistance for 150V Voltmeter & 10A Ammeter
  • Thread starter Thread starter lilkrazyrae
    Galvanometer
The discussion focuses on utilizing a galvanometer with a 90-ohm internal resistance to create a 150V voltmeter and a 10A ammeter. To construct the voltmeter, a series resistor of 4.29 x 105 ohms is required. For the ammeter, a shunt resistor must be connected in parallel with the galvanometer to allow for the measurement of 10 amps while ensuring full deflection of the galvanometer coil.
  • Understanding of galvanometer operation
  • Knowledge of series and parallel resistor configurations
  • Familiarity with Ohm's Law
  • Basic electrical circuit analysis skills
  • Research how to calculate series and parallel resistances
  • Learn about shunt resistor design for ammeters
  • Study the principles of galvanometer calibration
  • Explore the application of Ohm's Law in circuit design
Electronics engineers, electrical technicians, and students studying circuit design who are interested in building and calibrating measurement instruments.
lilkrazyrae
A galvanometer of 90 ohms internal resistance has a full-scale current of 350. microA. Describe how to use this meter to make : (a) a 150 V voltmeter, and (b) a 10.0A ammeter
So (a) Resistors must be connected in series with the galvanometer, R=4.29 x 10^5 ohms.
(b) A shunt resistor must be used in parallel with the galvanometer. :smile:
Find the voltage required to give the galvanometer coil full deflection and then figure out what resistor carrying 10 amps of current will provide that voltage drop. That resistor placed in parallel with the galvanometer will be a 10 amp ammeter.
AM
15K
