Solving a Raft Submersion Problem - Edge Needs a Second Opinion
  • Thread starter Thread starter edge
The discussion centers on calculating the percentage of a wooden raft submerged when an 80 kg man jumps onto it. The raft has a density of 600 kg/m³, a surface area of 5.8 m², and a volume of 0.60 m³. The correct calculation shows that the total mass of the raft and the man is 440 kg, leading to a displaced volume of 0.44 m³ of water. Consequently, the percentage of the raft submerged is determined to be 73%, as the displaced volume is divided by the raft's total volume.
  • Understanding of buoyancy principles
  • Knowledge of density calculations
  • Familiarity with volume displacement concepts
  • Basic algebra for solving equations
  • Study Archimedes' principle in detail
  • Learn about buoyant force calculations
  • Explore density and volume relationships in fluid mechanics
  • Practice problems involving submerged objects and buoyancy
This discussion is beneficial for physics students, engineers, and anyone interested in fluid mechanics and buoyancy calculations.
edge
Okay, I've worked this problem and have what I think is the correct answer...I just want to get a second opinion because I am a little bit unsure.
A raft is constructed of wood having a density of 600 kg/m^3. It's surface area is 5.8 m^2, and its volume is .60 m^3.
- A 80 kg man jumps on the raft. After a while, the man + raft system becomes stable. What is the % of the raft submerged?
My work:
I assume that at equilibrium the weight of the raft + man must equal the buoyant force.
I use mass = (density)*(volume) to get the mass of the raft (360 kg) then add 80 kg to get the new mass, 440 kg. Now I take that mass times gravity to get the weight. And set that equal to the buoyant force of (density of water)*(volume displaced)*(gravity). It looks like this:
(440)g = (1000)(V)(g)
so 440/1000 = v
that gives me .44 as the displaced volume of water.
This is where my question arises. Is 44% the amount of the raft submerged? Or do I then need to divide the displaced volume by the volume of the raft (.44/.6) to get .73 or 73%?
If I've worked it wrong please let me know but I think I've done it correctly...I'm just unsure which of the 2 answers is the correct one.
Thanks!
-edge
It's asking for the percentage of the raft that is submerged, not the volume, so the answer is 73%.
If you keep track of units, you can check because percentages should always be unit-less.
Awesome, thanks. Silly me, simple errors...they kill me. Thanks for the help!
10K
