Solving for r: Finding Electric Field When Gravitational Fields Equal Zero
The discussion revolves around determining the electric field when gravitational forces are balanced, specifically in the context of a proton suspended in an electric field and the gravitational influence of the Earth and Moon during a spacecraft's journey. The participants are exploring how to find the electric field without knowing the radius.
  • Participants discuss the balance of forces acting on the proton, including gravitational and electric forces. There is uncertainty about how to calculate the electric field with an unknown radius, and some participants express confusion regarding the relationship between electric fields and forces.
The discussion is ongoing, with participants providing insights into the nature of the forces involved and suggesting that the problem may lead to a quadratic equation. Some guidance has been offered regarding the relationship between electric and gravitational forces, but no consensus has been reached on the specific calculations required.
Participants are grappling with the implications of not knowing the radius in their calculations and the nature of electric fields versus forces. There is mention of Newton's universal gravitation law and the need to consider both Earth and Moon's gravitational effects.
hippolyta2078795
A proton(m=1.67 * 10^-27 kg) is suspended at rest in a uniform electric field E. Take into account gravity and determine E.
How do I find the field if I don't know what r is.
A spacecraft makes a trip from the Earth to the Moon, 380000km away. At what point in the trip will the gravitational field be zero? The mass of the Moon is about 1/81 that of Earth.
I understand this problem I think, but I want to make sure. I plug the numbers in for Newton's universal gravitation law. I have to fields, one exerted by the Earth, one by the moon. I set the radius in the moon's field as (380000000-r)meters. Right?
What you are doing in the first problem is looking at two balanced forces. One of the forces is weight (force due to gravity) which is found by w=mg. The other force is the electrstatic force which can similary be found by multiplying two things together.Second one, yes you are on the right track. You will get to a point where it might look like the quadratic formula will come up, but...
"cross multiply and square root both sides." Saves a lot of time.
What are those things. I don't know how to find the magnitude of a field with an unknown radius. Thanks.
You don't need the radius for calculate this electric field.
It more clear with the anterior aclaration, specialy the one that say something like "its about 2 forces in equilibrium".
The electric field is not a force at all, but a description of how the force (electric one) interact with the environment more clearly with other electric charges (correct me some one if I am wrong). In short you will not use the formula for the electric field, but calculate the "magnitude".
Or a hint, you can use a deduction the one that goes from show how to get the electric field from the electric force, the answer of what you need is there also the formula (that you don't need here is there).
  • · Replies 16 ·
