Electric Potential: Finding Points of Zero Potential Along X Axis
The discussion focuses on determining points of zero electric potential along the x-axis due to two charges: 3 C at 14 cm and -4 C at 15 cm. The potential is calculated by setting the contributions from each charge equal, utilizing the formula V = kQ/r, where V is the electric potential, Q is the charge, and r is the distance from the charge. The potential is positive near the positive charge and negative near the negative charge, leading to the conclusion that the zero potential points must be located either to the left of 3 C, to the right of -4 C, or in between the two charges.
  • Understanding of electric potential and its mathematical representation.
  • Familiarity with Coulomb's law and the concept of electric charge.
  • Basic algebra skills for solving equations.
  • Knowledge of the behavior of electric fields and potentials in one-dimensional space.
  • Study the concept of electric potential in multi-charge systems.
  • Learn how to apply the principle of superposition to electric potentials.
  • Explore the graphical representation of electric potential functions along a line.
  • Investigate the effects of additional charges on the electric potential in a plane.
Students of physics, electrical engineers, and anyone interested in understanding electric potential and charge interactions in electrostatics.
brad sue
Hi,
I have this problem:
Two charges are placed along the x axis; 3 C at 14 cm, and -4C at 15cm. Find those points along x-axis where the potetial is zero.
I don't know how to start here. Please can I have some help.
I have the same problem with 4 charge in a plane. Is the procedure the same as this one?
But I need to understand this one first.
Thankx
The First problem:
First of all, you know that it has to be either to the right of -4C, to the left of 3C, or in the middle.
You know the distance between the charges (I'll call it d). So if a point is x distance from the first charge (3) it is x+d distance from the second one if the point is to the left of 3C, x-d if it is to the right of 4C, and d-x if it's in the middle. Now for each of those cases you can make an equation were the potential of one charge equals the the potential of the other were for the distances (r) you use the pair of distances that go with that case ((x,x+d),...). In each of the cases you solve for x.
So you just have to find an x were the forces of each charge are equal.
Brad Sue - you're finding where Electric Potential V = 0 , right? (Not Force).
V is positive very near a positive charge, and is negative very near a negative charge. Far enough away from them both, the "measurer" only sees the total charge, so potential should be negative far away (tending to 0 as 1/x).
I would sketch this function along the x-axis in 6 regions: near
13.8, 14.2; 14.8, 15.2; 0, 25 ; connect the dots to see zero-crossings.
Contributions to the Electric Potential (at a location) by each charge add,
kQ/r , where r is the distance from the source charge to that location
(as explained by Daniel)
