Calculating Home Heat Pump Efficiency & kW-hrs of Heat Delivered
The discussion revolves around calculating the efficiency of a home heat pump, specifically focusing on the relationship between the heat absorbed from the ground and the electrical energy required to operate the system. The context includes the temperatures of the ground and the interior of the house, as well as the efficiency of the heat pump compared to a Carnot refrigerator.
  • Participants are attempting to identify the relevant formulas for calculating the coefficient of performance (COP) of the heat pump and its efficiency. Questions about the relationship between temperature and efficiency, particularly in absolute terms, are raised. There is also a request for guidance on the general equations suited for this problem.
The discussion is ongoing, with participants exploring different aspects of the problem, including the need to convert temperatures to absolute values and the implications of efficiency in relation to the Carnot cycle. Some guidance has been offered regarding the use of the coefficient of performance formula, but no consensus has been reached on a specific approach.
Participants note that the temperatures should be considered in absolute terms for efficiency calculations, and there is an emphasis on understanding the relationship between the heat pump's efficiency and the temperatures involved.
Nusc
In a home heat pump, heat is absorbed from the Earth by a fluid circulating in buried pipes and delivered to the home interior. Suppose that the heat pump is 40% as efficient as a Carnot refrigerator. If the ground surrounding the pipes is at 5`C and the interior temperature of the house is kept to 20`, how many kilowatt-hours of heat would be supplied to the home interior for ever kilowatt-hour of electrical energy needed to operate the refrigerator?
omega = .4
[itex]\ Q_C=20 C[/itex]
[itex]\ Q_H=5 C[/itex]
[itex]\omega = Q_C/W[/itex]
Well we can solve for the work but were looking for kilowatt-hours,
E=Power X time.
Can someone lead me in the right direction and provide the general equation suited for this problem?
Thanks
What else can one say about the efficiency as it relates to the hot and cold temperatures, which should be in absolute temperature (K) not (C), although when one is looking at temperature difference, either unit is acceptable.
So what formula is associated with this problem?
omega = .4
As Astronuc says, work out the coefficient of performance of a Carnot cycle between these temperatures.
Since the COP ([itex]\omega[/itex]) of this cycle is 40% that of the Carnot cycle, you can determine the input work (W) required using your formula [itex]\omega = Q_C/W[/itex]. [Note:[itex]Q_C[/itex] is the heat removed from the cold reservoir. The output heat [itex]Q_H[/itex] is [itex]Q_C + W[/itex]]
AM
  • · Replies 19 ·
  • · Replies 23 ·
14K
