Physics Problem 22: Mass of Charged Object in Electric Field
  • Thread starter Thread starter mustang
    Physics
The discussion revolves around determining the mass of a charged object placed in a uniform electric field, specifically focusing on the forces acting on the object and the conditions for equilibrium. The subject area includes concepts from electromagnetism and mechanics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between electric force and weight, questioning the appropriate formulas to use. There are inquiries about specific terms and clarifications on the nature of forces acting on the charged object.
Participants have explored various formulas related to electric fields and forces, with some guidance provided on the correct expressions to use. There is an ongoing examination of how the forces balance when the object is floating, but no consensus on a complete solution has been reached.
Some participants express confusion regarding the terminology and the formulas applicable to the problem, indicating a need for clearer definitions and understanding of the concepts involved.
mustang
Problem 22.
given: g=9.814m/s^2.
An object with a net charge of 40 uC is placed in a uniform electric field of 572 N/C, directed vertically.
What is the mass of this object if it floats in this electric field? In units of kg.
Note: What formula would you use?
Use Equilibrium Condition, Relation b/w Field and Force
I need more help. What does "b" and "w" mean?
"b" and "w" don't mean anything. humanshu121 was using b/w to mean "between".
I having a hard time solving problem since I don't know what formula I should use and the values to "sub" in.
What is the formula for the force experienced by a charge q in an electric field of magnitude E?
Would that formula be Electric field strength=Coulomb constant* charge producing the field(q)/(distance)^2.
No -- that formula describes the strength of the field PRODUCED by a charge q.
You want the force EXPERIENCED by a charge q under the influence of a field from some other source.
Is the formula electric force=Coulomb constant*(charge1)(charge2)/(distance)^2
Not exactly, but you could find the right one "hidden" in there (because in there you have included the expression that you wrote up above for the field produced by a charge).
I'm comfused?
You have two forces,
1.weight from the mass acting towardds the earth
2.an electric force from the electric field, the key equation here is that: the force on a charged particle is its charge times the field -> F = qE
Note: Coulomb law is that just mentioned without the charge of the particle in question. Coulmbs law is with q1 and q2 is between two paticles, in this case the electric field is probably produced by large metal plates with millions of particles in them - point is how the field is made is not important.
If the field E1 produced by a point charge q1 is
E1 = keq1/r2
and the force exerted on point charge q2 by point charge q1 is
F12 = keq1q2/r2
just substitute the formula up above for E to get
F12 = q2E1
Here, you aren't dealing with 2 point charges. Instead you have 1 point charge in a uniform field from some unspecified source. But as dodger said, the formula above can be generalized, so the force on a charge q from any uniform field is
F = qE
Now you just have to find the conditions so that force exactly offsets the weight of the particle -- basically a geometry question.
This subject should not be a confusing thing, a field is produced by charged stuff and this exerts a force on other charged stuff, the size of this force (as given by the equation i said) tells you how big a force acts on the charged thing. Stop and think about it - if you have a charged particle in an electric field and you double its charge the effect on it goes the same - the force on it doubles. The same effect would happen if the field was doubled - the force on it would double.
Right.
And forget about my unnecessary "geometry" comment.
There's really no geometry to deal with here. One force (the weight) acts straight down and the other (the electrical force) acts straight up (do you see why?).
If the object floats, these two forces must be equal, right? Simple algebra. Just solve for m.
So F=qE is bascially F=ma, Right.
Right; well, F=qE=F=mg.
I assume you meant g, right?
So the equation to solve this problem is qE=mg, where g=9.81m/s^2, E=572N/C, and q= 40*10^-6.
Correct.
Thanks!
Thank you!
  • · Replies 68 ·
9K
  • · Replies 26 ·
