Can anything really be at rest?
  • Context: Graduate
  • Thread starter Thread starter TheAtheistKing
    Rest
The discussion centers on the concept of whether anything can truly be at rest, exploring implications in classical and quantum mechanics. Participants examine definitions of momentum, the relationship between momentum and rest, and the consequences of quantum uncertainty on the notion of rest.
  • One participant argues that if a particle is at rest, then its momentum must be zero, leading to the conclusion that the wavelength must be infinite, which is not possible, suggesting that nothing can truly be at rest.
  • Another participant references the uncertainty principle, stating that if a particle were at rest, the uncertainty in its momentum would be zero, resulting in infinite uncertainty in its position, thus contradicting the idea of a particle being at rest.
  • A participant challenges the definition of momentum presented, suggesting that it is merely an equation rather than a true definition, proposing that momentum should be defined as the ability to impart impulse.
  • Concerns are raised about the implications of defining momentum in classical terms while discussing quantum mechanics, with one participant questioning the coherence of relating classical and quantum definitions.
  • Another participant questions the assumption that a quantity like wavelength cannot be infinite and seeks clarification on the definitions and operational meanings of terms used in the discussion.
  • Some participants express skepticism about the idea that if nothing can be at rest, then all particles must be accelerating, and they question the implications of this on the concept of time and motion.
Participants express multiple competing views on the definitions and implications of rest and momentum, with no consensus reached on whether anything can truly be at rest or the validity of the definitions presented.
Discussions involve unresolved definitions of key terms such as momentum and wavelength, and participants highlight the complexity of relating classical mechanics to quantum mechanics without clear operational definitions.
TheAtheistKing
We set speed v=0 all the time in physics, and reach neat and tidy conclusions, but can anything really be at rest? I am interested in criticisms to the following line of reasoning:
Definition of momentum
[tex]\vec P = mass*velocity = M \vec v[/tex]
And from this it follows that the magnitude of the momentum of a particle is equal to the particle's mass times the particle's speed.
In quantum mechanics the magnitude of the momentum of a particle is equal to Planck's constant divided by the wavelength of the particle.
[tex]|\vec P| = \frac{h}{\lambda}[/tex]
Hence we have:
[tex]m|\vec v| = \frac{h}{\lambda}[/tex]
So if something is at rest, then we have:
[tex]0 = \frac{h}{\lambda}[/tex]
But nothing can really be infinite, so lambda cannot be infinite, hence the RHS must be nonzero. Hence if the fundamental relation of quantum mechanics is correct, then it follows that nothing can have speed |v|=0, hence no particle can be truly at rest.
Notice I have ignored the center of mass of bodies, but so focus on particles for now. Can any particle truly be at rest? If the above line of reasoning is fine, then wouldn't that mean that in any inertial reference frame whatsover, any particle is accelerating? And if that is the case, would this not explain why there was a second moment in time? And would this not explain why relative motion cannot cease?
Any thoughts?
With the uncertainty principle, the product of the uncertainty of position and of momentum is greater than a small constant. So if you had a particle at rest, the uncertainty in its momentum would be zero, and hence the uncertainty of its position would be infinite. It could be anywhere in the universe, and any measurement that told you where would increase the uncertainty of its momentum, leading it to be no longer at rest. So uncertainty agrees with you calculation based on the older quantum mechanics.
No. This is not a true definition of momentum. It is an equation, which is a vicarious mathematical convenience. Momentum, IMO, is better defined in words as: the ability to impart impulse.
Hence we have:
This quote begins with, "In quantum mechanics ...," and has a classical mathematical relationship as a conclusion. IMO, this is disjoint and nonsensical.
But nothing can really be infinite, so lambda cannot be infinite, ...
Why does lambda qualify as "not nothing?" First, define lambda. Then, decide whether or not it should follow this strange rule of not being infinite. I don't understand where you got this rule, or why it should apply to lambda since it has not yet been defined.
... in any inertial reference frame whatsover, any particle is accelerating?
That's a very interesting way to look at it.
I don't follow.
One symbol was defined as the product of two other symbols. If you know the meaning of those two symbols, then you know the meaning of this definition. One symbol is 'v' for velocity, which is adequately defined mathematically, using a three dimensional rectangular coordinate system. Let (x1,y1,z1) be the coordinates of a particle, at some moment in time in some reference frame. The position vector of the particle relative to the origin of the frame is:
R = x1i + y1 j + z1 k
where i,j,k are unit vectors
The velocity of the particle is the derivative of the position vector in this frame with respect to time in this frame.
The other term in the definition is M for mass. It is not immediately clear whether or not M is a function of v. Perhaps the best thing to do would be to provide for M an operational definition, in other words a way of measuring mass. If we assume that inertial and gravitational mass are equivalent, then weighing two bodies in a constant gravitational field would give a method of measuring mass, and hence we would have an operational definition of M. On the other hand, if they are not equivalent then we would have to use collision analysis. But in either case, M can be operationally defined, and the meaning v is clear based upon mathematical work spanning the past 2000 years alone. A particle is too small to have its speed in a frame measured, so no operational definition of v can ever be given.
Momentum then is simply the product of these two variable quantites.
Why criticize such a simple definition? Is impulse a more basic concept of physics than momentum?
Planck's constant divided by wavelength has the same units of the P that was defined, so perhaps they are equivalent. Even if they aren't equivalent, so long as they are proportional, an arbitrary constant will not affect the conclusion we are seeing here. The question then is, are they proportional?
Why can't lambda be left undefined? What is an operational definition of lambda? Why does the concept that no quantity of physics is infinite qualify as strange?
I don't follow.
Here I think the guy is just seeing the obvious. If nothing can truly be at rest in an inertial frame, then in no inertial reference frame can anything be moving at a constant speed. Hence, at the beginning of time, every particle which was somewhere was simultaneously subjected to a nonzero force, which would mean that in any inertial reference frame the particles were being observed from, those particles would move relative to one another, providing a second state.
I was merely appealing to the wishes of TheAtheistKing:
Any thoughts?
Originally posted by Tempest
Originally posted by turin One symbol was defined as the product of two other symbols.
Correction: "one physical quantity was equated to the product of two other physical quantities. I don't appreciate the patronization. It is quite obvious to me, as I'm sure to anyone who reads the post, what those "symbols" are intended to represent. That was not the issue I wanted to address. The issue at hand is whether this particular equation is suitable as a definition. It may seem like I am arguing semantics, and in a way I am and appologize. But in this case it is a nontrivial distinction. Momentum is just not generally defined by this equation, period, plane and simple, whether or not my definition is appropriate by the standards of more accomplished and rigorous physicists. If you want to use the term "momentum" and define it with this equation, then we don't really have anything more to say to each other about it.
Agreement of units is hardly a condition on which to base an identity. So the units agree, that doesn't really tell you anything positive. Agreement of units is one of the many considerations in determining whether or not a relationship is legitimate.
It can be. But my point was exactly that: so far I don't see any operational definition or physical significance for lambda whatsoever in TheAtheistKing's treatment. If I'm playing basketball, I sure hope that I don't have to adhere to the rules of soccer; it would be awefully difficult to play the game without using my hands. Until lambda is defined, at least in some way, how could rules be imposed on it? I can say this: if lambda has the same meaning to which I am accustomed, then this relationship between the QM and CM momenta should not be taken so seriously as to make such a profound claim.
It is not a strange requirement for physical, or should I say, tangible quantities, but so far I don't see how lambda fits into this category of quantities.
Well, it may be obvious to geniuses like yourself, but I was hoping to hear some feedback from the author. I would like TheAtheistKing to elaborate on what was meant.
wow i think there is too much thinking going on here...The question was, can anything ever have zero (none, null, 0) velocity movment positional change...the answer is sure, provided you meet this one small thing...Figure out a way to stop the millions of millions of trillions of strings that are vibrating in that object...Thats all there's too it...He didn;t ask how to do it he just asked if it could be done...How to do it would be a far better and more fun question don't you think? :smile:
I think the Atheist King's whole point is that you shouldn't be too sure. Here we see a quantum mechanical argument which results in the conclusion that no particle can be at rest. He didn't say that the center of mass of a body couldn't be at rest. As for strings, they are theoretical entities, as are point particles. One has a zero dimensional object as the fundamental unit of matter, the other has a one dimensional object as the fundamental unit of matter. Both units are theoretical.
And he made a very interesting observation, which is that if the momentum of a particle really is given by Planck's constant divided by the wavelength of the particle, then every particle is accelerating in any inertial reference frame, which would literally be why there was a second moment in time. I am still thinking about this thread.
If you think about it, if all the particles in the universe were free at the first moment in time, then the law of inertia would rule each and every particle. Nothing would move. On the other hand, if there were forces between every particle, then each particle would accelerate, and thus they would move relative to each other. So what he is clearly saying is this:
Granted that the quantum mechanical relation for momentum of a particle is correct, it follows that there are no such things as free particles in nature. Thus, all particles are 'connected' somehow, exerting forces between each other. This should remind you of gravity. If every particle in the universe gravitationally attracts every other particle, then no particle is ever force free, which is his main conclusion.
No. Being in a state of perfect rest would mean being at temperatures of absolute zero, which is made impossible by the thermodynamics.
You cannot win- you can not get something for nothing because matter and energy are conserved.
You cannot break even- you cannot return to the same energy state, because entropy always increases.
You cannot get out of the game- because absolute zero is unattainable.
Dr. Michio Kaku, Hyperspace
Does anyone know how to construct a mathematical argument using thermodynamics, which results in the conclusion that relative motion cannot cease. I'd be interested in looking at it.
Thanks
Food for thought on ideal physical situations!
TheAtheistKing, I think this is closely related to your thread! If you don't feel that way, I apologize. I think they are fundamental questions which everyone should be able to answer: however, I am apparently a certified crackpot.
How many of these statements are true?
1.) An ideal clock measures time! That is, the admonishment "only if it is at rest in the frame of reference being used" is a superfluous constraint on the truth of the statement.
2.) The concept of an "ideal clock at rest" does not violate any concepts of Quantum Mechanics!
3,) The reading on an ideal clock in motion is not a direct measure of the change in proper time along its space-time trajectory.
4.) Time and proper time are exactly the same thing!
5.) Only a crackpot would ask such nonsensical questions.
Have fun -- Dick
Wavelength is inverse of frequency. Corresponding to infinite wavelength would be frequency of 0. Why would it be unthinkable to consider frequency of 0?
Seems like particle with zero momentum equivalently does not exist.
Makes me think of vacuum..
I believe you can be at rest.
Consider an inertial reference frame attached to an electron. Anything in this frame is at rest relative to the electron.
Concerning the second question as to the logic of the momentum derivation. I agree that if we think of momentum as force times the time the force is applied, or as the author said impulse, we come to a better understanding. Force and momentum are related through a derivative. Force is the measure of how momentum changes with time. According to the photoelectric effect and common experience (sun bathing for instance) we know light carries energy and therefore exerts a force. The problem arises when we associate momentum strickly with mass. The equation p=mv is, in my opinion, a special case of momentum and not a complete definition.
Why would you be sure about that? While sitting on my chair I'm following geodesics of spacetime that I perceive as gravity force. What keeps electron together? If it even is "together".
It falls through to meaning of mass. Light carries mass too.
You are off the topic. A reference frame can be attached to the electron. This is done all the time in relativity.
Mass and energy are related by the speed of light. Since light is pure energy it can have momentum but no mass. It all depends on our concept of mass and its relation to energy. All the original poster is doing is manipulating equations without a knowledge of their meaning.
If you go back and look at the original poster's argument, he concluded that in any inertial reference frame, a particle must be accelerating. That being the case, any coordinate system which is attached to an electron does not represent an inertial reference frame (because the electron is changing speeds in any inertial reference frame). But, as was said, that conclusion is contingent upon the following equation being true:
An inertial reference frame is defined as a coordinate system where a point mass can only move in a straight line with constant velocity. So any frame a particle is accelerating in is not inertial.
  • · Replies 29 ·
