| Thread Closed |
Finding a basis for a subspace of P_2 |
Share Thread | Thread Tools |
| Feb16-06, 10:16 PM | #1 |
Let [tex] W=\lbrace p(x) \in P_{2} : p(2)=0\rbrace [/tex]
Find a basis for W. Since a basis must be elements of the set W we know that p(2)=0. So if [tex]p(x)=ax^2+bx+c[/tex], then [tex]p(x) = 4a+2b+c=0[/tex]. Let c=t, b=s and s,t are real scalars. Then p(x) can be written as [tex] t(-\frac{1}{4} x^2+1)+s(-\frac{1}{2}x^2+x) [/tex] so the basis would be [tex]\{ (-\frac{1}{4} x^2+1), (-\frac{1}{2}x^2+x)\rbrace [/tex]. Does anyone see a problem with this? |
| Feb17-06, 03:07 AM | #2 |
Recognitions:
One problem is the line:
p(x) = 4a + 2b + c = 0 It should say: p(2) = 4a + 2b + c = 0 The final answer is correct, however it isn't clear as to how you got it. How do you go from the line above to saying that p(x) can be written: t(-x²/4 + 1) + s(-x²/2 + x)? Also, why bother changing c to t and b to s? You haven't proven that the set you've chosen consists of elements of W, spans W, and is linearly independent. Of course, it is all of those things, but you haven't proved it. There's a simpler solution: you know that W is not all of P2 (since there are polynomials with 2 not being a root), so since P2 has dimension 3, you know that W has dimension 2 or less. If you can find 2 linearly independent elements of W, then you're done, since you know that these two will span all of W. And it should be obvious that if you can find a linear element of W and a quadratic element of W, then these two will be linearly independent. The obvious choice for the quadratic element is the (x-2)², and the obvious choice for the linear element is x-2. |
| Feb17-06, 06:02 AM | #3 |
Actually, since I am so bad with fractions, I think I would have solved for c: c= -4a- 2b so any such polynomial can be written as ax2+ bx- 4a- 2b. Taking a= 1, b= 0, gives x2- 4. Taking a= 0, b= 1, gives x- 2. Having already said that "any such polynomial can be written as ax2+ bx- 4a- 2b" it is immediate that that {x2- 4, x- 2} spans this space. That fact that one contains x2 and the other doesn't makes it clear that they are independent. Your result is correct but, as AKG said, you need to explain your steps in more detail. |
| Feb17-06, 10:02 PM | #4 |
Finding a basis for a subspace of P_2How could I show that the dimension of W is 2 unless I know a set that spans W has two vectors? Let me read on... |
| Feb17-06, 10:05 PM | #5 |
Thanks for showing me an alternative solution....I have a test comming up in the next week or so....I think I'm gonna
| Thread Closed |
| Thread Tools | |
Similar Threads for: Finding a basis for a subspace of P_2
| finding basis for subspace | Calculus & Beyond Homework | 3 | ||
| [SOLVED] Finding a basis for a subspace | Calculus & Beyond Homework | 8 | ||
| Basis for a Subspace. | Precalculus Mathematics Homework | 6 | ||
| Finding a basis for a subspace | Calculus & Beyond Homework | 3 | ||
| basis for subspace | Linear & Abstract Algebra | 10 | ||
