How Does Density Affect Calculations in Thermodynamics Problems?
This discussion focuses on solving thermodynamics problems that involve density calculations. Specifically, it addresses the work done by a 1.0 kg bar of lead heated from 25°C to 60°C, utilizing the equation Work = Pressure * Change in Volume. Additionally, it covers how to calculate the number of silver atoms in a droplet with a radius of 0.6 mm using the density of silver (1.05 x 104 kg/m3) and Avogadro's number (6.022 x 1023 atoms/mol). The correct approach involves calculating volume, mass, and moles systematically.
  • Understanding of density as Mass/Volume
  • Familiarity with the Ideal Gas Law (PV=nRT)
  • Knowledge of Avogadro's number (6.022 x 1023 atoms/mol)
  • Ability to calculate volume of a sphere using V = (4/3)πr3
  • Learn about the coefficient of linear expansion and its application in thermodynamics
  • Study the relationship between pressure, volume, and temperature in thermodynamic systems
  • Explore the concept of molar mass and its significance in converting mass to moles
  • Investigate advanced thermodynamic equations and their applications in real-world scenarios
Students and professionals in physics, chemistry, and engineering fields, particularly those focusing on thermodynamics and material science.
Blade
I'm stumped on some of the thermodynamic problems involving density.
Heat a 1.0kg bar of lead at atmospheric pressure from 25C to 60C and find the work done by the lead. (density of lead = 1.13*10^4 kg/m^3)
The only equations I was given was the Ideal Gas Law... which lead is not a gas.. Someone also told me that apparently work=pressure*volume, which also doesn't help. Density is molar mass/volume (I think), which does nothing in this case, since I basically already can determine both those components. Where do I start?
[Answer=.02729J]
A droplet of silver has a radius of .6mm. How many silver atoms are in the droplet. The density of silver is 1.05*10^4 kg/m^3
This sounds simple, but I must be missing a conversion. I'm sure I'm suppose to multiply something by Avogradro's number, but not sure how to get the info from the density and radius.
(Answer=5.3*10^19 atoms)
[Answer=.02729J]
I'm thinking you would need the coefficient for linear expansion for the lead. Then you would have the change in volume. Since the pressure is N/m^2. If you multiply the pressure by the change in volume (m^3), you get Nm which is J.
find volume:
v = (4/3)[tex]\pi[/tex]r^3
v = (4/3)[tex]\pi[/tex](0.0006)^3
v = 9.0478*10^-10 m^3
find mass:
(9.0478*10^-10 m^3) * (1.05*10^4 kg/m^3) = 9.5*10^-6 kg = 0.0095g
use molar mass to find mols:
0.0095g * 1mol/107.87g = 8.807*10^-5 mols
use avogadro's number to find atoms:
8.807*10^-5 mols * 6.02*10^23 atoms/mol = 5.30185*10^19 atoms
Yep, still got it :wink:
Hi there,
I can understand how thermodynamics problems involving density can be challenging. Let me try to break it down for you.
First, let's review the definition of density. Density is the mass of a substance per unit volume. In other words, it is how much matter is packed into a certain amount of space. The equation for density is:
Density = Mass/Volume
Now, let's look at the first problem given. We have a 1.0kg bar of lead that is being heated from 25C to 60C. To find the work done by the lead, we need to use the equation:
But wait, we don't have the change in volume. However, we do know that the density of lead is 1.13*10^4 kg/m^3. Using the definition of density, we can rearrange the equation to solve for volume:
Volume = Mass/Density
Since the mass is given as 1.0kg, we can plug that in along with the density to find the volume of the lead bar at 25C. Then, using the Ideal Gas Law (PV=nRT), we can find the volume at 60C. The change in volume will give us the value we need to calculate the work done by the lead.
Now, for the second problem, we have a droplet of silver with a given radius and we need to find the number of silver atoms in it. First, we need to calculate the volume of the droplet using the formula for the volume of a sphere:
Volume = (4/3) * π * radius^3
Once we have the volume, we can use the density of silver to find the mass of the droplet. Then, using the molar mass of silver (107.87 g/mol), we can convert the mass to moles. Finally, we can use Avogadro's number (6.022*10^23) to find the number of atoms in the droplet.
I hope this helps guide you in solving these problems. Remember to always review the definitions and equations involved in thermodynamics and think about how they can be applied in each scenario. Good luck!
  • · Replies 17 ·
