Fitzgerald-Forentz contraction problem
  • Thread starter Thread starter capslock
    Contraction
The discussion revolves around a problem involving the Fitzgerald-Lorentz contraction, where two individuals on a moving train attempt to measure the distance between two points marked on the ground after dropping bags of flour from the front and back of the train. The train is 500m long and travels at a speed of 0.7c. Participants are exploring whether the measurements taken after the train stops will demonstrate the contraction effect.
  • Participants question the implications of being in the same inertial frame and whether relativistic effects apply. There is discussion about the expected measurement outcome and the relevance of Lorentz transformations in this context.
Some participants suggest that the distance measured on the ground will be greater than 500m, indicating a demonstration of the contraction. Others are clarifying terminology regarding the equations used and the nature of the measurements being taken.
There is a mention of confusion regarding the application of relativistic effects and the definitions of the frames involved in the measurement process. Participants are navigating through the implications of their assumptions about inertial frames and length measurements.
capslock
Dear All, Have a small problem:
Two chaps attempt to demonstrate the phenomenon of Fitzgerald-Lorentz contraction. The two meet at the centre of a fast train which is L = 500m long and traveling at a speech of u = 0.7c to synchronize their watches.
One sits at the front of the train while the other sits at the back. At a previously agreed time, both drop a bag of flour from the train so that it marks the ground beneath. When the train has stopped, they drive back to where they dropped the bags and measure the distance between the two marks. What distance do they measure? Have they actually demonstrated the Fitzgerald Lorentz contraction?*CONFUSED* Surely as they are in the same train, they are in the same inertial frame of reference? And hence, relativistic effects will not be relavent?
same as each other? same as the ground?
or same as they will be when they measure on the ground?
Do you think they'll measure 500m? And NOT demonstrate contraction?
yes, they will have demonstrated the LF contraction. When they go measure the distances on the ground, it will be larger than 500 m.
If you call the train the S` frame, this is a measurement corresponding to delta t'=0 and delta x'= 500 m. Plug that in the LF equations and find Delta x. That will be the value they will measure on the ground.
LF equations? I'm working from the Lorentz equations. How do I derive them?
Best Regards, James
Best Regards, James
Same equations.. LF= Lorentz-Fitzgerald, which is what you call Lorentz equations. Sorry.
Btw, you are right that they are in the same frame, but they are effectively making a length measurement in the frame of the ground, so relativistic effects are relevant.
Pat
  • · Replies 60 ·
  • · Replies 54 ·
  • · Replies 33 ·
