What is the Potential at the Origin for a Uniformly Charged Semi-Circle?
  • Thread starter Thread starter brad sue
    Potential
The potential at the origin due to a uniformly charged semi-circle with charge density (lambda) and radius (R) is calculated using the formula V = (lambda) / (4 * epsilon 0). The derivation involves integrating the potential contributions from differential charge elements (dq) along the semi-circle, where dq is expressed as (lambda) * R * d(theta). The constant k is defined as 1 / (4 * pi * epsilon 0), confirming the result through proper integration from 0 to pi.
  • Understanding of electrostatics and electric potential
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of charge density concepts
  • Basic principles of coordinate systems in physics
  • Study the concept of electric potential due to different charge distributions
  • Learn about the integration of electric fields and potentials in various geometries
  • Explore the applications of Gauss's Law in electrostatics
  • Investigate the effects of varying charge densities on potential calculations
Students studying electrostatics, physics educators, and anyone interested in advanced topics in electric potential and charge distributions.
brad sue
I have this problem for homework and I would like to check my work:
Charges are distribyted with uniform charge density (lambda)along a semi circle of radius R, centered at the origin of a coordinate system.
What is the potential at the origin?
I did this:
dV=k*dq/R where k=1/4*pi*(epsilon 0)
but dq=(lambda)*R*d(theta) theta is the small angle between two position on the semi circle.
pi
then V =| k*(lambda)*R*d(theta) / R (integral from 0 to pi)
After computation I found: V=(lambda)/(4*epsilon 0)
Thank you
Looks ok.
  • · Replies 18 ·
