What Happens to the Particle's Energy When the Box Size Changes?
  • Thread starter Thread starter allanm1
    Box Particle
The discussion revolves around the "particle in a box" problem in quantum mechanics, specifically focusing on the implications of changing the size of the box on the energy of the particle. Participants explore the relationship between the box dimensions and the energy states available to the particle.
  • Participants discuss the effects of changing the box size on the particle's energy, questioning what happens if the new energy levels do not match the original energy. There is consideration of the speed at which the box walls are moved and the resulting state of the particle.
The discussion is ongoing, with various perspectives being explored. Some participants suggest that the energy state may change depending on how the box is altered, while others question the assumption of energy conservation during this process. Guidance has been offered regarding the implications of moving the walls slowly versus abruptly.
There is a mention of the assumption that the energy of the particle is conserved, which is being questioned in light of the box size change. The discussion also touches on the concept of work being done on the system when the box dimensions are altered.
allanm1
"Particle in a box" question
The solution of Schrodingers equation for the simple "particle in a box" problem is:
E = (n^2)(h^2) / 8m(L^2)
where L = the length of the box.
See http://en.wikipedia.org/wiki/particle_in_a_box"
Say that the initial energy of the particle is E1.
If at a later time the length of the box is changed (a moveable wall), then there are now a completely new set of possible energies available, for n=1,2,3 etc. What if none of these new allowed energies equals the original energy of the particle?
What happens to the energy difference?
Nobody can answer?!
It depends on how slowly the walls of the box are moved.
Suppose they are abruptly removed. I.e. they instantly vanish. The particle state is now in a superposition of the eigenstates of the new box and will settle into one of them upon measurement. In any case, the energy upon measurement wil be different than originally.
Particle in a box
In my original question I was assuming that the energy of the particle was
conserved after changing the size of the box.
Was I wrong in assuming this. Maybee changing the size of the box does work on the particle? Like compressing a gas if there were many particles.
Is it the energy state n that is conserved?
Please confirm.
Hi allanm1,
Yes, if you move the walls of the box slowly then the particle will always be in the ground state. In this case you must clearly have done work on the system since the energy of the system is changing.
Hope this helps.
