Finding a Method for Incremental Output in Java
5 replies · 5K views · last reply
Yoss
I was curious if anyone knows if there are any methods to do the following in java.
I'm writing a terminal based program in java, and it will be doing incremental updates. I want to output to the terminal the percentage done, but to replace the last output. For example:
$>java jprog
Percent completed...0%
$>java jprog
Percent completed...5%.
Instead of
$>java jprog
I checked the java API's a little, in the PrintStream and OutputStream classes, but couldn't find any methods like that. Anybody know? Thanks.
Standard output by itself cannot do such a thing. To accomplish this, your Java program actually needs to control the terminal window which shows the output. I suggest you look into implementations of "curses" in Java, for example:
http://sourceforge.net/projects/javacurses/
- Warren
I'm not sure if your Java app can read termcap/terminfo, but it should be possible to send terminal control characters (or maybe backspace) to move the cursor around. (That's what curses does after all.)
You could display the information in an alternate manner. For example, you could plot a graph:
#===1===2===3===4===5===6===7===8===9===#
And fill up the line below it one character at a time as it progresses. For example, at 22.5%, it would look like:
#===1===2=
and the cursor is at the end of the second line, ready to display another character as necessary.
You can make this prettier if you're willing to assume an equal width font.
If you're willing to assume a *NIX-style environment, the character '\r' is a carriage return (without the line feed) -- it positions the cursor at the beginning of the current line. You could use this to achieve the effect you describe. (Backspace would usually work too, as mentioned)
Thanks for all of your suggestions guys, but I did find out a good way to do it:
'\b'.
:E
edit: oops Nate didn't see your reply!
Yoss,
Care to share what you did? I am writing a load tool and I want to print a running throughput average to the console.
Thanks.
