Uniform circular motion and Ferris wheel
The discussion revolves around a problem involving uniform circular motion, specifically related to a rider on a Ferris wheel. The problem asks for the magnitude of the force exerted by the seat on the rider when positioned halfway between the top and bottom of the wheel.
  • Participants discuss the application of force summation equations and the role of centripetal force in circular motion. Some question whether the problem is solely concerned with vertical forces, while others explore the implications of horizontal forces in maintaining circular motion.
Participants are actively engaging with the problem, questioning the original poster's reasoning and exploring different interpretations of the forces involved. Some guidance has been offered regarding the distinction between vertical and centripetal forces, but no consensus has been reached on the correct approach.
There appears to be confusion regarding the forces acting on the rider, particularly in distinguishing between vertical forces and the centripetal force required for circular motion. The problem's setup and the assumptions made by the original poster are under scrutiny.
zolloz89
my teacher said my answer is wrong but i cannot figure out why
there is a ferris wheel. a rider in the ferris wheel is 35kg. the radius of the ferris wheel is 12m. it asks what is the magnitude of the force does the seat exert on the rider when he is halfway between the top and the bottom?
i got 343N by using the force summation equation, Fnet = Fn + Fg = 0 because there are no other forces acting on the rider in the vertical direction
Fg=35kg x 9.8m/s^2 = 343, Fn=-Fg, Fn=-(-343) = 343N
please help me understand why my methods are wrong
thanks in advance
thanks in advance
The Ferris wheel is moving the rider in a circle, presumably at a constant angular speed, so the net force on the rider is equal to the centripetal force. In the vertical direction, you are correct: Fnet(vert)=0 N. What about in the direction of the center of the Ferris wheel? Since the rider is not sliding in that direction, friction must be keeping him there. That's the origin for the centripetal force at this point in the motion.
-Dan
Between top and bottom, the centipetal force is pointing inwards, in horizontal, not vertical. And let's assume it wasn't, if you balance out centripedal force, how would he accelerate and draw a cirle (relative to the observe on the ground, of course).
i think it is only asking about the vertical force on the rider exerted by the seat
...which equals to his weight.
yeah so that would equal normal force which would be 35kg x 9.8m/s^2, right
11K
