Calculating Charge and Tension in a Uniform Electric Field
The discussion centers on calculating the charge on a cork ball and the tension in a string when suspended in a uniform electric field with components of 3.00 x 10^5 N/C (x-direction) and 5.00 x 10^5 N/C (y-direction). The ball, with a mass of 1.00g, is in equilibrium at an angle of 37 degrees. The tension in the string is determined using the formula F = mgcos(53 degrees), while the charge on the ball is calculated using F = qE, where F represents the force due to the electric field.
  • Understanding of Newton's laws of motion
  • Familiarity with electric fields and forces
  • Knowledge of trigonometric functions in physics
  • Ability to perform equilibrium analysis in mechanics
  • Study the principles of electrostatics and electric fields
  • Learn about tension forces in static equilibrium
  • Explore the relationship between charge and electric force using Coulomb's Law
  • Investigate vector decomposition in physics for force analysis
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of charged objects in electric fields and the principles of static equilibrium.
frozen7
A charges cork ball of mass 1.00g is suspended on a light string in the presence of a uniform electric field has an x compenent of 3.00 x 10^5 N/C and a y component of 5.00 x 10^5 N/C, the ball is in equilibrium at [tex]\theta[/tex] = 37 degree. Find:
(a) the charge on the ball
(b) thetension in he string
I do it in this way:
Since the ball is in equilibrum, so the net force acting on the ball is equal to zero. These are 2 forces act on the ball, one is mgcos53 (acting 37 degree below -x-axis), the other one is acting in a opposite direction. Since the ball is in equilibrium, the force which act in opposite direction is equal to mgcos53 as well.
So, we can conclude that the tension in the string is F=mgcos53 and the charge on the ball can be calculated by using the formula : F=qE
Am i doing correctly?
Thanks in advance.
There are three forces acting on the ball: the weight (which acts downward), the force due to the tension in the string, and the force due to the electric field.
Since the ball is in equilibrium, these forces must add to zero. Consider x and y components separately.
Thanks. Problem solved.
  • · Replies 31 ·
