How Does Current Divide in a Series Circuit with Different Resistors?
  • Thread starter Thread starter fish
    Current Resistor
The discussion focuses on calculating the current through two resistors in a series circuit: a 2 ohm resistor and an 8 ohm resistor, powered by an 8V and 16V battery configuration. Using Kirchhoff's junction rule, the current through the 2 ohm resistor (I_1) is determined to be 4 A, while the current through the 8 ohm resistor (I_2) is calculated to be 1 A. The calculations confirm that the potential difference in the circuit loop equals zero, validating the setup and sign conventions used in the analysis.
  • Understanding of Kirchhoff's laws, specifically Kirchhoff's junction rule.
  • Basic knowledge of Ohm's Law and its application in circuit analysis.
  • Familiarity with series circuits and how current flows through resistors.
  • Ability to perform algebraic manipulations to solve for current in electrical circuits.
  • Study advanced applications of Kirchhoff's laws in complex circuits.
  • Learn about series and parallel resistor combinations and their impact on current and voltage.
  • Explore the concept of power dissipation in resistors using the formula P=I^2R.
  • Investigate the effects of varying voltage sources on current distribution in series circuits.
Electrical engineering students, circuit designers, and anyone interested in understanding current flow in series circuits with multiple resistors.
fish
what is the current through the 2 ohm resistor?
what is the current through the 8 ohm resistor?
8 V
. empty space .
. empty space . I
. empty space .
...2 ohm Res...
. empty space .
. empty space 8 ohm Res
. empty space . I_2
. empty space .
16 V
! = (-) side of battery
| = (+) side of battery
I_1 is on the 2 ohm branch (current going left to right)
I current going down (clockwise)
I_2 current going down (clockwise)
Is this setup right with correct sign conventions?
I_2=I+I_1
2 ohm res:
+8V-2I_1=0
8=2I_1
I_1=4 A
8 ohm res:
-8V-8I_2+16V=0
8V=8I_2
I_2=1 A
8 V
. empty space .
. empty space . I
. empty space .
...2 ohm Res...
. empty space .
. empty space . I_2
. empty space .
16 V
I_2=I+I_1
This is correct by Kirchoff's junction rule.
2 ohm res:
+8V-2I_1=0
8=2I_1
I_1=4 A
8 ohm res:
-8V-8I_2+16V=0
8V=8I_2
I_2=1 A
Yes, this is correct. The potential difference in a circuit loop is equal to zero.
However a more correct way to present your answer would be:
[tex]8V-I_1(2\Omega)=0[/tex]
[tex]8V=I_1(2\Omega)[/tex]
[tex]I_1=4A[/tex]
[tex]-8V-I_2(8\Omega)+16V=0[/tex]
[tex]8V=I_2(8\Omega)[/tex]
[tex]I_2=1A[/tex]
It's good practice to keep units in your work.
thanks redrogue
  • · Replies 16 ·
