Practical Weight Loss Strategy: Stair Climbing for Efficient Fat Burning
  • Thread starter Thread starter Jacob87411
The discussion revolves around the physics of energy expenditure related to weight loss through stair climbing. The original poster presents a scenario where a student aims to lose weight by running up and down stairs, raising questions about the calculations involved in determining the energy required to burn a specific amount of fat.
  • Participants explore the conversion of fat to energy and the calculations for work done while climbing stairs. There is confusion regarding the correct force to use in the work calculation, with some questioning whether to use the weight of the person or the force of gravity. Others discuss the efficiency of energy conversion in the body and how it affects the total energy expenditure needed to lose weight.
The discussion is ongoing, with participants providing different interpretations of the physics involved. Some have offered insights into the calculations, while others are questioning the assumptions made about energy expenditure and efficiency. There is no explicit consensus on the correct approach yet.
Participants are working under the constraints of a homework problem, which may limit the information available for calculations. The discussion includes assumptions about energy efficiency and the simplification of energy expenditure during the exercise.
Jacob87411
I worked this out but I must of gone wrong somewhere
Energy is conventionally measured in Calories as well as in joules. One Calorie in nutrition is one kilocalorie, defined as 1 kcal = 4186 J. Metabolizing 1 g of fat can release 9.00 kcal. A student decides to try to lose weight by exercising. She plans to run up and down the stairs in a football stadium as fast as she can and as many times as necessary. Is this in itself a practical way to lose weight? To evaluate the program, suppose she runs up a flight of 100 steps, each 0.150 m high, in 61.5 s. For simplicity, ignore the energy she uses in coming down (which is small). Assume that a typical efficiency for human muscles is 20.0%. Therefore when your body converts 100 J from metabolizing fat, 20 J goes into doing mechanical work (here, climbing stairs). The remainder goes into extra internal energy. Assume that the student's mass is 56.0 kg.
(a) How many times must she run the flight of stairs to lose 1 lb of fat?
First off, we have to convert. When 1 lb of fat is burned that is 453.592 g. Each gram of fat burned requires 9.00 kcal as the problem states which is equivalent to 37674 J. So to burn 1 g of fat you need to work off 37674 J so to burn 453.592 g of fat one must burn (453.592)(37674)=17088625 J.
Ok so to the physics:
W=Fd
The distance is the vertical distance going up the stairs which is 100(.15m)=15m.
I got confused on what the force should be, is it the force of gravity which would be 56(9.8)?
If so W=fd = (560)(15) = 8400 but only 1/5 of that work goes towards metabolizing fat so 1680 J per time up the stairs. Then you take the total amount of joules needed to be burned / 1680 and get a huge, unreasonable number..any help is appreciated
The force of gravity is 9.8 and not 56
Its not the persons weight, mg? So the force per flight of stairs is W=fd=(9.8)*(15)
So the work to go up 1 flight of stairs = 29.4 J, and you need to burn17088625 J so 17088625/29.4 is the number of times she must go up the stairs, which equals 581,245?
1/5 of that work goes towards mechanical work not metabolizing fat.
The total fat used up is 5 times the energy used in doing mechanical work. This is coz 20% of used fat is used to generate energy to do mechanical work. So even the other 80% is also lost from the body.
So the energy used in work going up the stairs * 5 is the amount of energy burnt on each run of the stair flight? So is the total amount she needs to burn in order to burn a lb of fat 17088625 J?
OUCH! w=mg. If m=56 kg, then w=56*9.8 N.
-Dan
10K
  • · Replies 21 ·
26K
10K
