Can You Multiply to Remove Water or Hydrogen in Balancing Redox Equations?
  • Thread starter Thread starter Dooga Blackrazor
    Redox
The discussion centers on the process of balancing redox equations in acid/base solutions. Participants confirm that while multiplying to achieve a common factor for electrons is essential, multiplying again to remove water or hydrogen after canceling electrons is not standard practice. Instead, in basic solutions, adding water can be used to balance out excess hydrogen. This method is crucial for achieving accurate redox balance.
  • Understanding of redox reactions and their components
  • Knowledge of balancing chemical equations
  • Familiarity with acid/base chemistry
  • Experience with basic and acidic solution properties
  • Study the principles of balancing redox reactions in acidic and basic solutions
  • Learn about the role of water in redox balancing
  • Explore examples of redox equations and their balancing techniques
  • Investigate common pitfalls in redox equation balancing
Chemistry students, educators, and professionals involved in chemical analysis or reaction balancing will benefit from this discussion.
Dooga Blackrazor
I am doing Redox Equations in Acid/Base. Anyway, I have one question. I know that you multiply to get a common factor for electrons. However, after you cancel out your electrons, can you multiply by another common factor to remove water or hydrogen? I am leaning towards no, but I am not sure.
Thanks
Show an example, I am not sure I understand what you mean.
You're balancing the equation, right? After you've added electrons to balance the charge, that should be your last step. However if the solution is basic, you can add water in order to cancel out all the hydrogens.
10K
