I don't understand why this is wrong (Work and kinetic energy problem)
The problem involves a block being lowered vertically with a specific acceleration, requiring calculations of work done by different forces and the block's kinetic energy. The subject area pertains to work and kinetic energy in the context of mechanics.
  • Participants discuss the equations used to calculate the forces acting on the block and question the sign conventions for acceleration and force. There is an exploration of how to correctly set up the equations based on the problem's conditions.
Participants are actively engaging with the problem, questioning the assumptions made about the direction of forces and acceleration. Some guidance has been offered regarding the correct formulation of the equations, but no consensus has been reached on the correct approach yet.
There is a noted confusion regarding the sign convention for acceleration and force, as well as the implications of taking the downward direction as positive. This may affect the calculations and interpretations of the forces involved.
frankfjf
Okay, here's the problem:
A cord is used to vertically lower an initially stationary block of mass M = 6.4 kg at a constant downward acceleration of g/2. When the block has fallen a distance d = 4.8 m, find (a) the work done by the cord's force on the block, (b) the work done by the gravitational force on the block, (c) the kinetic energy of the block, and (d) the speed of the block. (Note : Take the downward direction positive)
For a I come up with the equation:
F - Mg = Mg/2.
Solving for F I get:
F = 3Mg/2
Plugigng this into the basic equation for work I get:
W = 3Mgd/2
But when I plug in my values for M, g, and d, I get a wrong answer. Why?
F - Mg = Mg/2.
F = 3Mg/2
W = 3Mgd/2
If there is a *downward* acceleration of g/2, it means that [itex]a_y = - g/2[/itex]. You used +g/2 in your equation.
But it says to take the downward direction to be positive.
All right. Then your equation should be -F + Mg = Mg/2
And then when you calculate the work done, F is upward and d is downward.
-Dan
  • · Replies 58 ·
  • · Replies 20 ·
