How do I calculate the final temperature when dropping ice into water?
The discussion focuses on calculating the final temperature when ice at -10°C is dropped into water at 20°C. The key equations involved are Q = mcΔθ for the temperature change of the ice until it reaches 0°C, and Q = mL for the phase change of ice to water at 0°C. Participants emphasize that the heat lost by the water must equal the heat gained by the ice, necessitating the use of both equations to arrive at the final equilibrium temperature. The latent heat of fusion for ice is crucial for accurate calculations after the ice reaches 0°C.
  • Understanding of thermodynamics principles, specifically heat transfer.
  • Familiarity with the equations Q = mcΔθ and Q = mL.
  • Knowledge of latent heat of fusion for ice.
  • Basic algebra skills for solving equations.
  • Study the concept of heat transfer in thermodynamics.
  • Learn how to apply the latent heat of fusion in phase change calculations.
  • Explore examples of heat exchange problems involving multiple substances.
  • Investigate the specific heat capacities of water and ice for more accurate calculations.
Students in physics or chemistry, educators teaching thermodynamics, and anyone interested in understanding heat transfer principles in phase change scenarios.
dan greig
I have a question about droping ice into water and working out the final temp.
ice is -10 and water is 20 degrees c, I know that from -10 to 0 I can use,
Q = m.c.delta theta
but does this give me the final answer or do i need to use, Q = m.l, after 0.
I think this because this equation is used when no change in temp occurs, also after 0 do i go back to original equation?
thanks, Dan
Not only will the ice be warming up, but the water will also be cooling down; this needs to be factored in also.
i realize that from -10 to 0
the heat lost by the water = the heat gained by the ice
but what i don't quite get is that after that how do come to a final figure?
I have been given the latent heat of ice so this makes me think it needs to be involved not just using,
Q=mc delta T
meaning (T - 30) and (30 - T)
As in -10 to 20 celsius.
  • · Replies 17 ·
