Need help designing ADC system -
The discussion focuses on designing an Analog-to-Digital Converter (ADC) system for an input frequency range of 300-3200Hz with a digitization error of 1%. The user inquires about the necessity of a band-pass or low-pass filter and the role of bit selection in maintaining the error threshold. The required sample rate is set at 8kHz, prompting questions about controlling higher chip rates. A basic block diagram is proposed, including components such as filters, sample and hold circuits, ADCs, and digital data buses. The Analog Devices website is recommended as a valuable resource for application notes, particularly AN-282.
  • Understanding of ADC principles and operation
  • Knowledge of signal filtering techniques, specifically band-pass and low-pass filters
  • Familiarity with sampling theory and Nyquist theorem
  • Experience with digital data bus architectures
  • Research "ADC design principles" for a comprehensive understanding of system requirements
  • Explore "band-pass vs low-pass filter design" to determine the best filtering approach
  • Learn about "sampling rate control techniques" to manage ADC chip rates effectively
  • Review "Analog Devices application notes" for practical design insights and examples
Electronics engineers, embedded systems developers, and students involved in ADC system design and implementation will benefit from this discussion.
envanyatar
Need help designing ADC system - URGENT!
I have to design a system where an analog input is converted to a digital output which will be sent to a parallel digital data bus using a ADC chip.
the specifications are that the input should be between 300-3200Hz with a digitisation error of 1%. for this do i use a band pass filter or a low pass only? how do you maintain under 1%? is it by choosing the number of bits?
also, the sample rate is to be taken at 8kHz. but the the rates in the Chips are all very much higher than this. How do you control that?
if a basic block diagram is to be drawn, should it be like this?
analog input, filter, sample and hold, ADC, (timer?? to control the sampling rate??), (shift registers? to convert from series to parallel??), digital data bus :confused:
What textbook are you learning about ADC systems from? A good source of information is the manufacturers who make the ADC chips. It's in their best interest to help you design a good circuit using their chips, so their Application Notes sections are usually full of great info and help.
I checked out Analog Devices website, and they have a long list of helpful Application Notes:
http://www.analog.com/en/DCcList/0,3090,760%255F%255F43,00.html
Start with a basic one like AN-282, and then look for notes that may fit your device or system requirements.
  • · Replies 51 ·
9K
