What is the Molecular Weight and Ionization Constant of Ascorbic Acid?
The discussion revolves around the determination of the molecular weight and ionization constant of ascorbic acid (vitamin C) through a titration experiment. Participants explore calculations related to the molecular weight, acid ionization constant, equilibrium constant, and pH at the equivalence point, while addressing specific challenges encountered in these calculations.
  • Homework-related
  • A participant describes the experimental setup and calculations for determining the molecular weight of ascorbic acid, noting the relationship between moles of acid and base at the equivalence point.
  • The same participant expresses difficulty in calculating the acid ionization constant due to uncertainty about the equilibrium expression's denominator.
  • Another participant suggests using the Henderson-Hasselbalch equation, indicating that the ratio of acid to conjugate base is necessary for the calculation.
  • One participant recommends using an ICE table to find equilibrium concentrations and suggests subtracting the concentration of H+ ions that reacted to determine the concentration of ascorbic acid at equilibrium.
  • Several posts reflect on the delayed responses to the thread, with participants commenting on the phenomenon of "necroposting" in online forums.
Participants express varying approaches to solving the problem, with no consensus on the best method for calculating the acid ionization constant or the equilibrium concentrations. The discussion remains unresolved regarding the specific calculations needed.
Participants have not fully clarified the assumptions or definitions needed for the equilibrium expression, and there are unresolved mathematical steps in the calculations presented.
erik-the-red
1) In an experiment to determine the molecular weight and the ionization constant for ascorbic acid (vitamin C), a student dissolved 1.3717 grams of the acid in water to make 50.00 milliliters of solution. The entire solution was titrated with a 0.2211-molar NaOH solution. The pH was monitored throughout the titration. The equivalence point was reached when 35.23 milliliters of the base had been added. Under the conditions of this experiment, ascorbic acid acts as a monoprotic acid that can be represented as HA.
(a) From the information above, calculate the molecular weight of ascorbic acid.
(b) When 20.00 milliliters of NaOH had been added during the titration, the pH of the solution was 4.23. Calculate the acid ionization constant for ascorbic acid.
(c) Calculate the equilibrium constant for the reaction of the ascorbate ion, A¯, with water.
(d) Calculate the pH of the solution at the equivalence point of the titration.
This was an AP Chemistry question in 1989.
I had no problems doing the first part. At the equivalence point, the number of moles of acid is equal the number of moles of base. I used this relationship to find out the number of moles, and grams / moles = molecular weight.
I have problems with part b, which consequently affects the correct answer to part c and d.
Because the pH is 4.23, I know the hydrogen ion concentration must be [tex]10^{-4.23}[/tex]. I know that the equilibrium expression is [tex]K_a = \frac{(A^{-})(H^{+})}{HA}[/tex]. So, I know the numerator is [tex](10^{-4.23})^2[/tex]. But, what is the denominator?
you should be able to use the henderson-hasselbach equation (assuming this is a buffer region), the sole information that you need now is the ratio of the acid and its conjugate base. You know how much base was added, and thus you should easily be able to calculate how much of the acid had reacted as well as how much of its conjugate base was produced.
this is easy.
use your ICE table to find the equilibrium concentration. then just minus off the concentration of H+ ions that reacted. you should get your concentration of ascorbic acid at equilibrium.
ZELEZNY said:
this is easy.
I appreciate your solution, but I'm surprised that you were able to find this thread, since I created it last year when I was in AP Chemistry.
Speaking of which, damn - that was a long time ago :bugeye:
This has to be the first time I've seen someone return after several months to respond to a necropost on a really old thread.
Damn!
Damn!
Had I not checked "e-mail notification," I would never have known.
Damn!
'Necropost'... I love it!
(it is typically done by first time posters)
Welcome to the Forum, ZELEZNY!
  • · Replies 16 ·
13K
