Eulers Equation confusion Are these the right equations?
  • Thread starter Thread starter mr_coffee
    Confusion
The discussion centers on Euler's equations for solving differential equations, specifically addressing the forms for one real solution and two complex solutions. The equations provided are: for one real solution, \( y = c_1 t^a + c_2 t^a \ln(t) \), and for two complex solutions, \( y = t^a (c_1 \sin(b \ln(t)) + c_2 \cos(b \ln(t))) \). The conversation highlights the need for additional forms when dealing with repeated roots and two real roots, as well as clarifying the meaning of the variable 'a' in relation to the roots of the characteristic equation. The participants also discuss the application of these equations in the context of differential equations of the form \( a x^2 y'' + b x y' + c y = 0 \).
  • Understanding of differential equations, specifically Euler-type equations.
  • Familiarity with characteristic equations and their roots.
  • Knowledge of logarithmic functions and their derivatives.
  • Basic proficiency in calculus, particularly in solving second-order differential equations.
  • Research the forms of solutions for repeated roots in differential equations.
  • Study the derivation and application of Euler's equations in solving differential equations.
  • Learn about the method of substitution in differential equations, particularly using \( u = \ln(x) \).
  • Explore the implications of complex roots in the context of differential equations.
Students and educators in mathematics, particularly those focusing on differential equations, as well as anyone preparing for exams involving Euler's equations and their applications.
mr_coffee
Hello everyone, I just went thorugh the pratice exam in about 15 minutes and got them all right but right when we were about to leave he also said you will need to do the following and he wrote the following:
Euler:
for 1 real solution:
USE:
y = c1*t^a + c2*t^a*ln(t);
2 complex:
USE:
y = t^a(c1*sin(b*ln(t)) + c2*cos(b*ln(t));
a is the real part
b is the imageary;
BUt he left out, what if you get repeated roots, also what if you get 2 real roots?
Also in his first equation:
USE:
What is a? is that like r?
y''+18y'+85 = 0;
r^2+18r+85 = 0;
r1 = -9+2i
r2 = -9-2i
like how those are r's, is that what he ment by a?
So i asked him, when would we use those forms? And he wrote, when you have a differential in the form of:
a*x^2y'' +bxy' + cy = 0;
So i wanted to test it out to see if it works, so i tried:
http://suprfile.com/src/1/2hef20/lastscan.jpg
And using it the old way obviouslly doesn't work, can someone tell me the other forms? like for 2 year solutions like this problem requires and for repeated roots? Thank you! Once i get these other equations i think i'll be able to figure it out.
Ivey I looked at what you posted in the last 2 threads i posted but the professor said its memorizing a few simple formulas, he doesn't want us to work it out or put it in a different form.
An "Euler type equation" has x to a power equal to the order of the derivative (that's why it's also called "equipotential"). Your example,
x2y"+ 2xy'- 30y= x3 is exactly of that kind. As for the substitution, u= ln x, I've also told you about that before.
If u= ln x, by the chain rule, dy/dx= (du/dx)(dy/du)= (1/x)dy/du and
d2y/dx2= (-1/x2)dy/du+ (1/x2)d2y/du2. Also x= eu so x3= e3u Your equation becomes
d2y/du2+ dy/du- 30u= e3u.
That should be easy.
THanks!
I think i got it,
m^2-m-6m-8 = 0;
m = 8,-1
y = Ax^r1+Bx^r2;
  • · Replies 16 ·
