| Thread Closed |
Light's limitations |
Share Thread | Thread Tools |
| Feb28-06, 05:38 PM | #1 |
Light's limitations
Hello,
I tried attaching this question in another forum's related thread, but no one has responded. I hope you don't mind me starting a new thread here. I think this forum is more suited to the question anyway. Here's the question: What are the energy and wavelength limitations of light? If you were to project the lowest energy beam possible from a fixed location and then accelerate away from that location travelling along the beam, what would happen? Would the beam always be hypothetically detectable? Is it possible for the energy level to drop so low that spin might be affected? Is it possible for the energy to drop so low as to affect the time dilation between the source and the accelerating vessel (essentially severing the reference frames)? What are the upper limits? If you were to project the highest energy beam possible and then accelerate toward it, what would happen? That is, if you're accelerating toward a high-energy beam at relativistic velocity, what unusual effects (if any) might you see? |
| Feb28-06, 05:48 PM | #2 |
There is no theoretical lower limit below which EM radiation could not be detected. There are, of course, enormous practical problems.
If you are moving with relativistic velocity toward a beam of EM radiation, its photons would appear severely blueshifted. Each photon's momentum, as measured in your frame, would be enormous. The resulting radiation pressure would act to slow you down. This same effect is the cause of the so-called "GZK cutoff" in the energy spectrum of charged cosmic-ray particles. For an ultra-relativistic charged particle, even the weak photons of the cosmic microwave background radiation are blueshifted enough to impart significant changes in momentum, thus slowing down such high-velocity particles. - Warren |
| Feb28-06, 06:37 PM | #3 |
Warren,
Thanks for the response. Also, what is the current thinking regarding the GZK paradox? And, wouldn't this effect tend to scatter light from distant sources? |
| Feb28-06, 07:07 PM | #4 |
Light's limitationsIf you have an EM wave with a wavelength of 10,000 light-years, it'll take a receiver 10,000 years to see a single cycle of it. You certainly couldn't use such a wave to transmit much information, because the maximum symbol rate would be 20,000 years per bit. The wave characteristics of the signal would be quite difficult to detect over any baseline less than 10,000 years, because the wave would appear to be a very close approximation to a static field over any (humanly) reasonable period of time. You can, of course, measure whether or not a static electric field exists in your laboratory, by simply watching what electrons do under its influence. It would be very difficult, practically, to detect the rate of change of a 10,000 light-year wavelength wave, however. Another proposed solution is that very high-energy neutrinos are created elsewhere in the universe. Neutrinos have such a small interaction cross-section (and only interact weakly) that they could travel enormous distances without ever interacting with anything, until some weak interaction transfers their energy to another particle which shortly hits Earth. - Warren |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Light's limitations
| light's reflection - wats ur perception? | General Physics | 9 | ||
| Light's Life | General Physics | 6 | ||
| Light's interaction with particles... | Chemistry | 4 | ||
| what does light's frequency actually mean? | General Physics | 5 | ||
| question about light's speed | General Physics | 7 | ||
