Calculating Acceleration in Pulley System with m_1 = 5.0 kg and m_2 = 4.0 kg
In a pulley system with masses m_1 = 5.0 kg and m_2 = 4.0 kg, the acceleration of m_2 can be calculated using Newton's second law. The equations governing the system are m_1a_1 = T_1 - m_1g and m_2a_2 = T_2 - m_2g. Both masses share a common acceleration and tension, allowing for the simultaneous solution of the two equations. Properly defining the direction of gravity and rotation is crucial for accurate calculations.
  • Understanding of Newton's second law of motion
  • Familiarity with free body diagrams
  • Knowledge of tension in pulley systems
  • Basic algebra for solving simultaneous equations
  • Study the principles of Atwood machines in physics
  • Learn how to construct and analyze free body diagrams
  • Explore the effects of friction in pulley systems
  • Practice solving simultaneous equations in mechanics problems
Students studying physics, particularly those focusing on mechanics and pulley systems, as well as educators seeking to explain the concepts of tension and acceleration in such systems.
dekoi
If [tex]m_1 = 5.0 \ kg \ and \ m_2 = 4.0 \ kg[/tex], what is the acceleration of [tex]m_2[/tex]?
I think the following equations describing the situation are correct:
[tex]m_1a_1=T_1 - m_1g[/tex]
[tex]m_2a_2=T_2 - m_2g[/tex]
But I don't know how I can go about solving for [tex]a_2[/tex].
Is there a relationship between the two tensions, and the two accelerations?
well in a pulley system the Tension on m1=m2g I am moslty sure but after my test today I am not sure what i know
Okay, take a deep breath. You are off to the right start, what with the Newton equations and all. Seems like you have a simple atwood pulley, where you have two hanging masses around a frictionless, massless pulley.
First thing you got to do is hit up the free body diagram. By correctly identifying that each mass experiences two forces, its weight and the corresponding tension of the rope, you can set them into their respective net force equations.
Here's where it gets tricky and easy, both at the same time. As the system moves (ya know, the masses move around the pulley) they seem to share something in common, and its not the tension. seems like both have the same sort of "movement" of you will. IN fact, they share a common acceleration! Not only that, but in this simple special case, they do indeed share a common tension as well! So whatyou have is two equations with two unknowns; a pretty simple mathematical procedure.
Here's the catch though. In your equations, you have the force of gravity to be negative for both of the masses. While gravity indeeds points downward, in this case, you must DEFINE a direction of rotation (clockwise or CC, it's totally up to you) as either positive or negative. By doing this, your free body diagrams will correctly label what is a "positve" force and a "negative" force.
I know this was a lot to handle, but try to rework it out and tell us what your final result for the acceleration of the system was. Good luck!
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 29 ·
  • · Replies 30 ·
  • · Replies 18 ·
