Gauss' Law: Discrete vs Continuous Charges
The discussion revolves around Gauss' Law and the behavior of Gaussian surfaces in relation to discrete and continuous charge distributions. Participants explore why Gaussian surfaces can pass through continuous charge distributions but not through discrete charges.
  • Participants question the conditions under which Gaussian surfaces can enclose charges, particularly focusing on the differences between discrete point charges and continuous charge distributions. Some discuss the implications of the electric field's definition in these contexts.
The discussion is active, with participants providing insights into the nature of charge distributions and the applicability of Gauss' Law. There is an exploration of the concept of charge distribution and its mathematical treatment, along with questions about the nature of electric fields at point charges versus continuous distributions.
Some participants express uncertainty about the definition of distributed charge and its implications for applying Gauss' Law. The discussion includes references to external resources for further clarification on the topic.
physicsprasanna
why is it that a gaussian surface cannot pass through discrete charges ... but can pass through a continuous charge distribution??
I believe technically, the Gaussian surface must enclose the charges, because Gauss's law applies to the enclosed charge.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/gaulaw.html#c2
The electric flux through an area is defined as the electric field multiplied by the area of the surface projected in a plane perpendicular to the field. Gauss's Law is a general law applying to any closed surface. It is an important tool since it permits the assessment of the amount of enclosed charge by mapping the field on a surface outside the charge distribution. For geometries of sufficient symmetry, it simplifies the calculation of the electric field.
Hyperphysics
For Gaussian surfaces -
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/gausur.html#c1
One can put a Gassian surface just outside a distributed charge.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/gausur.html#c3
i mean ... yes, the gaussian surface should enclose charges .. but the surface should not pass through a discrete charge... but it can pass through a continuous charge distribution ... why is that?
id assume its fairly hard for it to pass through a point charge as you take the "size" of the charge to be 0 and therefore it cannot have anything pass through it, a continuous charge distribution however has a size and then the surface can pass through it
may i know what is distribution charge?
The electric field of a continuous charge distribution is everywhere defined, while the field of a point charge doesn't exist right at the location of the point charge. I believe that singularity is what invalidates the use of Gauss' law when the surface passes through it.
thanks for the replies ... maybe it is due to the fact that the field due to a charge does not exist at the place of the charge.
Thanks once again!
Simply a collection of charges, but mathematically we treat them as 'uniformly' distributed rather than discrete units.
In a line conductor, the charge is 'linear charge density' or charge/unit length (e.g. C/m).
On a surface conductor, one takes of charge/unit surface (e.g. C/m2) area as though the charges were 'smeared' on the surface. In a conductor, the net charge occurs near the surface because this represents least energy, and the charge units (electrons) are mobile.
In a dielectric, the charges are much less mobile and one can have a volumetric distribution (even non-uniform) of charge.
See - http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elefie.html#c1
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/gaulaw.html#c4
  • · Replies 26 ·
  • · Replies 22 ·
