How to Calculate the Molar Heat of NH4Cl Solution?
  • Thread starter Thread starter RevoLuTioN31
    Heat
The discussion focuses on calculating the molar heat of an NH4Cl solution using experimental data. The experiment involved dissolving 0.9 g of NH4Cl in 23.5 g of water, resulting in a temperature drop from 21°C to 19°C. The specific heat of water is established at 4.186 J/g°C, and the calculation for molar heat involves determining the moles of NH4Cl, computing the heat lost by water, and applying the formula C ΔT/n, where C is the heat capacity of water. The assumptions made include treating the heat capacity of the dilute solution as equivalent to that of water.
  • Understanding of molar calculations and stoichiometry
  • Familiarity with specific heat capacity concepts
  • Basic knowledge of calorimetry
  • Ability to perform temperature change calculations
  • Research the specific heat of NH4Cl for more accurate calculations
  • Learn about calorimetry techniques for measuring heat transfer
  • Explore the concept of enthalpy of solution and its calculations
  • Study the principles of dilute solutions and their heat capacities
Chemistry students, laboratory technicians, and anyone involved in thermodynamic calculations related to solute-solvent interactions.
RevoLuTioN31
Hello,
I am doing a lab currently where we are required to find the Molar Heat in kJ / mol of salt dissolved of the salt, NH4Cl
To start the experiment, I dissolved the salt into an amount of water (values below) and recorded temperature changes.
Mass of NH4Cl = .9 g
Mass of H2O = 23.5 g (mL of water as well)
Temperature initial of Water = 21°C
Temperature final of Solution = 19°C
Procedure: I placed the 23.5 mL of water in a styrofoam cup, took the temperature and then added the salt. I mixed the salt around and took the temperature again at it's lowest point. I know the specific heat of water is 4.186 J / g°C. I do not know the specific heat of NH4Cl.
I am unsure where to go from here. Do I find the specific heat of NH4Cl online and then solve for its temperature initial? Am I doing the experiment wrong or is there another experiment to find the Molar Heat of the Solution (defined to me as the amount of heat given or taken from the salt)? :confused: Thanks for the help.
Since you've not been instructed to measure an initial temperature for sal ammoniac, you are faced with a necessity/ies to make assumptions; assumption a) could be that the final solution is dilute enough that its heat capacity is equal to that of water, and ΔHsol'n = 24.4 x 4.186 x 10-3 kJ x 2.00 /(0.9 mol/53.5).
1. compute how many moles n of NH4Cl you have
2. Compute the heat lost by the water
3. answer = C ΔT/n
where C = water heat capacity.
This is approximate & assumes mass of solute << mass of solvent.
This is chemistry a field in which I'm no expert so take it with the proverbial grain of NaCl.
  • · Replies 20 ·
