Little question on the potential in a conducting spherical shell
The potential of a conducting spherical shell with a positive charge Q on a small metal sphere of radius a (where a < b) and a total charge of -Q on the shell is determined by the formula V_total = kQ(1/r - 1/b). The inner radius of the shell compensates for the sphere's charge, while the outer radius has no charge, resulting in V_outer = 0. The textbook's assertion that V_total = kQ(1/a - 1/b) is incorrect in the context of measuring potential at a specific point, r = a. The correct approach involves understanding the potential differences between specified points.
  • Understanding of electrostatics and electric potential
  • Familiarity with the concept of conducting spherical shells
  • Knowledge of point charges and their potential equations
  • Basic grasp of electrostatic equilibrium principles
  • Study the derivation of electric potential for point charges and spherical conductors
  • Learn about the properties of conductors in electrostatic equilibrium
  • Explore the implications of charge distribution on conducting shells
  • Investigate potential differences in electrostatic systems
Physics students, electrical engineers, and anyone studying electrostatics or working with electric fields and potentials in conductive materials.
Lisa...
The question is:
A conducting spherical shell of inner radius b and outer radius c is concentric with a small metal sphere of radius
a < b. The metal sphere has a positive charge Q. The total charge on the conducting spherical shell is –Q. What is the potential of the metal sphere?
I thought: The potential of the metal sphere is measured when a < r < b and V= Vmetal sphere+ Vinner radius of shell+Vouter radius of shell
1) The metal sphere is to be considered as a point charge, therefore [tex]V_s_p_h_e_r_e= \frac{kQ}{r}[/tex]
2) The inner radius has charge -Q in order to compensate the charge of the metal sphere and if a< r < b then r < the inner radius of the metal sphere (b). Because the rule for a spherical shell is:
[tex]V= \frac{kQ}{r}[/tex] if r > R
[tex]V=\frac{kQ}{R}[/tex] if r < R
with R the radius of the spherical shell and r the distance from its center
V inner radius of shell= [tex]\frac{kQ}{b}[/tex]
3) The outer radius has charge 0 because a charge of -Q is induced on the inner sphere, a charge of +Q will be found on the outer spherical shell which already was -Q before the electrostatic equilibrium was established. Therefore Q outer radius= 0 and V outer radius=0
Summerizing:
Vtotal= [tex]\frac{kQ}{r} + \frac{kQ}{b} = kQ{\frac{1}{r} - \frac{1}{b}[/tex]
though my textbook tells me Vtotal= [tex]kQ{\frac{1}{a} - \frac{1}{b}[/tex]
So who is right and who is wrong?
How can you have an r in your answer? You are asked for the potential at a particular point, r = a.
(1) What's the potential difference between points r = b & r = a?
(2) What's the potential difference between r = b & r = c? (Don't forget it's a conducting shell.)
(3) What's the potential difference between r = c & r = infinity? (The outer surface has zero charge.)
Thank you I've figured it out now :)
  • · Replies 19 ·
10K
  • · Replies 43 ·
