Find Potential Integral: Solve \frac{(r')^2 - 2 (r'') r}{r^2}
  • Context: Graduate
  • Thread starter Thread starter gulsen
    Integral
The discussion revolves around finding the potential from a given force expression, specifically \(\frac{(r')^2 - 2 (r'') r}{r^2}\). Participants explore integration techniques and the nature of the variables involved, with references to classical mechanics.
  • One participant expresses difficulty in integrating the force expression provided.
  • Another participant questions the definitions of \(r'\) and \(r''\), suggesting they are likely functions of an independent variable.
  • A participant presents a related expression but notes that it does not account for all terms in the original force expression.
  • There is a contention regarding whether the force should be represented as a scalar or vector quantity, with some arguing for the necessity of a unit vector.
  • One participant proposes a potential form \(V= \frac{\dot{r}^2}{2r}\) and suggests that integration may not be necessary.
  • A participant expresses frustration with perceived pedantry in responses and calls for more constructive answers.
  • Another participant mentions a previous thread about integration techniques, hinting at alternative approaches to solving the problem.
Participants do not reach a consensus on the best approach to the problem. There are competing views on the representation of force and the necessity of integration, as well as differing interpretations of the variables involved.
There are unresolved questions regarding the definitions of \(r'\) and \(r''\), and the discussion reflects a mix of assumptions about the nature of the force and potential involved.
gulsen
I have a force and need to find the potential, but I'm stuch at a point. Any ideas how to integrate this: [tex]\frac{(r')^2 - 2 (r'') r}{r^2}[/tex]
what are r' and r''?
Likely unknown functions of an independent variable, say t,
something close is
[tex]\left( -\frac{r^{\prime}}{r}\right) ^{\prime} = \frac{(r^{\prime})^2-r^{\prime\prime}r}{r^2}[/tex]
but this leaves the term [tex]-\frac{r^{\prime\prime}}{r}[/tex] unaccounted for
also close is
[tex]\left( -\frac{(r^{\prime})^2}{r}\right) ^{\prime} = r^{\prime}\frac{(r^{\prime})^2-2r^{\prime\prime}r}{r^2}[/tex]
but has an extra factor of [tex]r^{\prime}[/tex] in it...
Are you sure that is the term to be integrated?
Mathematicians...
Unfortunately, I'm sure this is the force to be integrated. It's a part of an exercise from Classical Mechanics, Goldstein, p32.
QUOTE=gulsen]I have a force and need to find the potential, but I'm stuch at a point. Any ideas how to integrate this: [tex]\frac{(r')^2 - 2 (r'') r}{r^2}[/tex]
[/QUOTE]
This is a scalar quantity! Force needs to be represented by a vector field.
You are missing something.
regards
sam
You can put a unit vector [tex]e_r[/tex] if you like. But it's so obvious that if we're talking about force, we're talking about a vector. And if you want a more precise definition, r is the distance of the particle to the center of force.
Instead of being so pedantic and saying "hey question wrong, question is incomplete, etc", will someone give a correct answer? Such posts have no use.
I think it works out better if you split the given in the question as
[tex]\frac{1}{r^2} \left( 1 + \frac{\left( r' \right)^{2}}{c^2} \right) - \frac{2}{c^2} \left( \frac{\left( r' \right)^{2}}{r^2} - \frac{r''}{r} \right)[/tex]
However, I am quite tired right now, so I may have made mistakes while doing the problem
Regards,
George
OK, here is a useful post. The potential you are after is;
[tex]V= \frac{\dot{r}^2}{2r}[/tex]
and you don't have to carry out any integration**. Just try to write your force in the form;
[tex]F=-\frac{\partial{V}}{\partial{r}} + \frac{d}{dt}(\frac{\partial{V}}{\partial{\dot{r}}})[/tex]
**Two months ago, I created a thread here called "Integrate This". The purpose of the thread was to share with people some of the tricks that I use in solving complicated integrals without going through a messy process of integration. Unfortunately, the thread was locked (I believe) for psychological reasons:biggrin: .Have a look at that thread, you may find some useful mathematical tricks in there.
regards
sam
  • · Replies 29 ·
  • · Replies 16 ·
  • · Replies 20 ·
