Solve Banked Curve Problem: theta=21deg, Mu=0, r=150m
The discussion focuses on solving the banked curve problem with parameters theta = 21 degrees, Mu = 0, and radius = 150 meters. The radial acceleration is calculated using the formula a = v^2 / r, leading to the conclusion that the speed of the car is v = 23.75 meters per second. The calculations involve breaking down the normal force into its x and y components, resulting in the equation tan(theta) = v^2 / (rg). The final answer is confirmed as correct, with a minor correction noted regarding a typographical error in the equation.
  • Understanding of uniform circular motion and radial acceleration
  • Knowledge of trigonometric functions, specifically tangent
  • Familiarity with Newton's second law of motion
  • Ability to manipulate equations involving forces and angles
  • Study the principles of uniform circular motion in greater detail
  • Learn about the application of trigonometric functions in physics problems
  • Explore advanced topics in dynamics related to banked curves
  • Investigate the effects of friction (Mu) on banked curves
Physics students, automotive engineers, and anyone interested in the dynamics of vehicles navigating banked curves.
N_L_
http://img138.imageshack.us/img138/2042/untitled15mr.jpg
theta = 21 degrees
Mu = 0
radius = 150 meters
a = radial acceleration of uniform circular motion
a = v^2 / r
The sum of all forces = m*a
Since the car is at an angle and Fn is always perpendicular I split it into X and Y components.
Fn in the x direction = Fn sin theta
Fn in the y direction = Fn cos theta
X direction: Fn sin theta = m (v^2 / r)
Y direction: no acceleration so Fn cos theta - Fg = 0
Fn = (mg / cos theta)
By substitution into the equation for the x direction:
( mg / cos theta ) * sin theta = m (v^2 / r)
mg tan theta = m (v^2 / r)
cancelling m and re-arranging...
tan theta = ( v^2 / rg )
v^2 = tan 21 / (150 * 9.8)
v^2 = 564.28
Is this answer correct?
Yes.
Your working is pefectly correct and the answer is correct.
There's just a little typo. You used a '/'-sign instead of a '*'-sign between the tan21 and the 150*9.8
Yes you are correct with the equations tan(theta) = v^2/rg.
  • · Replies 24 ·
