Real & Imaginary parts of a finite product
The discussion revolves around determining the real and imaginary parts of a finite product of complex numbers, specifically expressed as \( P_n = \prod_{k=1}^{n} (x_k + iy_k) \), where \( x_k \) and \( y_k \) are real numbers. Participants explore the implications of expanding this product and the conditions under which the terms are real.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the general formula for expanding the product and question when the resulting terms will be real. There is mention of writing the terms in polar form to simplify the expressions. Some participants analyze the patterns observed in the expansions for small values of \( n \) and consider relating these patterns to symmetric polynomials.
The discussion is ongoing, with various approaches being suggested, including the use of polar coordinates. Some participants have provided insights into the complexities of the argument of the product and how it affects the real and imaginary parts. There is an exploration of the implications of these findings, particularly regarding infinite products.
Participants note the challenges posed by the branch cut structure in complex analysis and the potential complications when translating polar forms back into Cartesian coordinates. There is also a consideration of the implications of working with infinite products, which introduces additional complexity to the discussion.
benorin
Insights Author
So I'm trying to work-out the real and imaginary parts of a finite product, put
[tex]P_n = \prod_{k=1}^{n} \left( x_k + iy_k\right)[/tex]
where the x's and y's are real numbers like you would expect.
Well, what is the general formula for expanding that product? And when are the terms going to be real? I know I'm just restating your question, but if you can answer each of those question you can do this. So where have you got to?
If you can write them in polar form it may be much neater. Do you know anything specific about the x's and y's? Of course a general version will be possible, just icky.
NOTE: I will edit this post in some time, but I have got the pattern all mixed-up in my head right now and must then come back to this later.
I cut my post short on account of something more important, allow me to continue: I have considered the first several expansions of [tex]P_n[/tex] for small n, I have noticed that the each term in the expansion contains exactly n factors, and that, alternately, the terms of the real and imaginary parts in the expansion of the product contain only an even or an odd number of x's or y's according as n even or n odd. The last sentence is complicated for me to write (and is almost certianly wrong,) but, perhaps, some examples will make up for that
[tex]P_1 = \prod_{k=1}^{1} \left( x_k + iy_k\right)= x_1 + iy_1[/tex]
the real part: [tex]\Re P_1 = x_1[/tex] contains only terms having an odd number of x's and an even number of y's (I speak not of the oddness nor the evenness of the subscripts, but rather that there is one (odd) x and zero (even) y's
vice-versa for the imaginary part
[tex]P_2 = \prod_{k=1}^{2} \left( x_k + iy_k\right)= x_1x_2-y_1y_2 + i(x_1y_2+x_2y_1)[/tex]
the real part: [tex]\Re P_2 = x_1x_2-y_1y_2[/tex] contains only terms having an even number of x's and an even number of y's
I intend to try to relate the pattern I fail to describe above to the symmetric polynomials, and get some sort of combinatorial closed form for the real and imaginary parts.
Try polar form
Try polar form? Let [tex]z_k=r_{k}e^{i\theta_k},[/tex] where [tex]r_k:=|z_k| \mbox{ and } \theta_k:=\mbox{Arg } z_{k}[/tex] so that
[tex]P_n = \prod_{k=1}^{n} z_k = \prod_{k=1}^{n} r_{k}e^{i\theta_k} = \left(\prod_{k=1}^{n} r_{k} \right) e^{i\sum_{j=1}^{n}\theta_j}[/tex]
let us put [tex]r:=\prod_{k=1}^{n} r_{k}\mbox{ and } \theta:=\sum_{j=1}^{n}\theta_j[/tex] so that we have
[tex]P_n =re^{i\theta} = r(\cos{\theta}+i\sin{\theta})[/tex]
and hence [tex]\Re{P_n} = r\cos{\theta}\mbox{ and } \Im{P_n} = r\sin{\theta}[/tex]
there is some considerations to be had presently, firstly (and without trouble,) we have
[tex]r = \prod_{k=1}^{n} r_{k} = \prod_{k=1}^{n} |z_{k}| = \prod_{k=1}^{n} \sqrt{x_{k}^{2}+y_{k}^{2}} = \sqrt{ \prod_{k=1}^{n} \left( x_{k}^{2}+y_{k}^{2}\right) }[/tex]
and here is the trouble,
[tex]\theta = \sum_{j=1}^{n}\theta_j = \sum_{j=1}^{n}\mbox{Arg } z_{j} \neq \mbox{Arg } \left( \prod_{j=1}^{n} z_{j}\right)[/tex]
where I have put [tex]\neq[/tex] since we have that pesky brach-cut structure to worry about, since
[tex]\mbox{Arg } \left( z_{1}z_{2}\right) = \mbox{Arg } z_1 + \mbox{Arg } z_2 + 2\pi i \cdot\mbox{floor}\left(\frac{\pi - \mbox{Arg } z_1 - \mbox{Arg } z_2 }{2\pi}\right)[/tex]
how does this generalize? Above, floor() is the floor function (a.k.a. the greatest integer function.)
Heck with it, close enough is: there exists an integer k such that
[tex]\theta = \sum_{j=1}^{n}\mbox{Arg } z_{j} = \mbox{Arg } \left( \prod_{j=1}^{n} z_{j}\right) +k\pi i[/tex]
How do I translate these back into x's and y's ?
There's no reason to be concerned with the Arg of the product. When you take the cos and sin to find the real and imaginary parts this is irrelevant.
The downside here is that in terms of x and y you have the cos or sin of a sum of arctan's. Whether this is more or less desirable than a hideous sum is up to you. Either way is not going to be too nice with a general batch of z's.
Of course you've probably noticed how much cleaner it is if you started in polar form, these are much more natural coordinates for complex multiplication.
Re & I am parts of infinite products
I am also considering finding the Re & I am parts of infinite products, (as they interest me.) For example, we know that for all complex [itex]z:=x+iy[/itex] the following hold:
[tex]\sin {z} = z\prod_{k=1}^{\infty} \left( 1-\frac{z^2}{k^2\pi ^2}\right)[/tex]
[tex]\mbox{sinh} {z} = z\prod_{k=1}^{\infty} \left( 1+\frac{z^2}{k^2\pi ^2}\right)[/tex]
[tex]\cos {z} = \prod_{k=1}^{\infty} \left( 1-\frac{4z^2}{(2k-1)^2\pi ^2}\right)[/tex]
[tex]\mbox{cosh} {z} = \prod_{k=1}^{\infty} \left( 1+\frac{4z^2}{(2k-1)^2\pi ^2}\right)[/tex]
and from
[tex]\sin (x+iy) = \sin (x)\mbox{cosh}(y)+i\cos (x)\mbox{sinh}(y)[/tex]
we have, for example
[tex]\Re \sin {(x+iy)} = \Re \left[ (x+iy)\prod_{k=1}^{\infty} \left( 1-\frac{(x+iy)^2}{k^2\pi ^2}\right) \right] = x\prod_{k=1}^{\infty} \left[ \left( 1-\frac{x^2}{k^2\pi ^2}\right) \left( 1+\frac{4y^2}{(2k-1)^2\pi ^2}\right)\right] = \sin (x)\mbox{cosh}(y)[/tex]
the I am part is similar...
What is the formula for the Re & I am parts of an arbitrary convergent infinite product in terms of an infinite product?
  • · Replies 19 ·
  • · Replies 16 ·
