Calculating Related Rates of a Filling Spherical Balloon
The discussion focuses on calculating related rates for a spherical balloon being filled with water. The surface area increases at a constant rate of 3 cm²/sec, leading to a derived radius increase rate of 1/(8π) cm/sec when the radius is 3 cm. Additionally, the volume of the balloon is calculated to be 800π/27 cm³ when the volume is increasing at a rate of 10 cm³/sec. The calculations utilize the relationships between surface area and volume, employing derivatives to find the rates of change.
  • Understanding of calculus, specifically derivatives and related rates
  • Familiarity with the formulas for the surface area and volume of a sphere
  • Knowledge of implicit differentiation techniques
  • Ability to manipulate equations involving π and constants
  • Study the concept of related rates in calculus
  • Learn how to derive the formulas for surface area and volume of spheres
  • Practice problems involving implicit differentiation
  • Explore applications of related rates in real-world scenarios
Students studying calculus, particularly those focusing on related rates, as well as educators looking for examples to illustrate these concepts in a practical context.
jimbo007
hey guys,
just wondering if i did this correctly
a spherical balloon is to be filled with water so that there is a constant increase in the rate of its surface area of 3cm2/sec .
a) Find the rate of increase in the radius when the radius is 3cm.
b) Find the volume when the volume is increasing at a rate of 10cm3=sec.
A=surface area, V=volume
a) i thought was fairly easy and got 1/(8Pi) cm/sec
b) was a bit more trickier here is what i did
(1) [tex]\frac{dV}{dt} = \frac{dV}{dr} \frac{dr}{dt}[/tex]
(2) [tex]\frac{dA}{dt} = \frac{dA}{dr} \frac{dr}{dt}[/tex]
from the question we have
[tex]\frac{dV}{dt}=10[/tex]
[tex]\frac{dA}{dt}=3[/tex]
[tex]\frac{dV}{dr}=4 \pi r^2[/tex]
[tex]\frac{dA}{dr}=8 \pi r[/tex]
from (2)
[tex]3=8 \pi r \frac{dr}{dt}[/tex]
so [tex]\frac{dr}{dt}=\frac{3}{8 \pi r}[/tex]
sub into (1) we get that r=20/3
so [tex]V=\frac{4}{3}\pi r^3=\frac{4 \pi}{3}(20/3)^3[/tex]
I did it slightly differently, using
[tex]\frac{dV}{dA}= \frac{\frac{dV}{dt}}{\frac{dA}{dt}}= \frac{r}{2}= \frac{10}{3}[/tex]
to find r and then V but I got exactly the same answer!
  • · Replies 30 ·
