Definition of Time in Modern Physics
  • Context: Graduate
  • Thread starter Thread starter dwf
    Definition Time
The discussion revolves around the definition of time in modern physics, exploring its role across various theories such as relativity, quantum mechanics, and classical physics. Participants examine whether time is merely a dimension or if it has deeper implications linked to physical laws like thermodynamics.
  • Some participants propose that in relativity and relativistic theories, time is treated as a dimension but differs from spatial dimensions due to changes in sign and the ability to bend in general relativity.
  • Others argue that in non-relativistic quantum theory, time remains a numerical value rather than an operator, contrasting with spatial position which is treated as an operator affecting wave functions.
  • A participant suggests that time might be defined by the second law of thermodynamics, linking it to the concept of irreversibility and disorder.
  • Another viewpoint expresses that while time is not a tangible entity, it is influenced by physical phenomena such as gravity and velocity, and its passage can be observed through events.
Participants express differing views on the nature of time, with no consensus reached on whether it is merely a dimension or if it has additional significance linked to physical laws.
The discussion highlights the complexity and variability in the definitions of time across different physical theories, indicating potential limitations in understanding due to the diverse contexts in which time is applied.
dwf
I´d like to know what´s the exact definition of time in modern physics. Is it just a dimension, and nothing else?
In relativity, and all relativistic theories like the standard model and string theory, time is one of the dimensions, but treated a little differently from the space dimensions (a change in the sign of some numbers). This is also true in general relativity, though there we find that the time dimension, as well as the space dimensions, can bend.
In non-relativistic quantum theory, which is still used, space position is a mathematical "operator" which chnges the value of a wave function, and corresponds to the physical operation of measuring a position. But time is not an operator for technical reasons, and reamains just a numerical value as in ordinary life - so many nanoseconds or whatever.
In classical physica, like ordinary physics 101, time is a number again, like we usually have it.
Having different time definitions seems confusing at first, and you wonder how unified all these different theories could be, with so many different "times". But you really have only three. All of relativistic quantum theory is consistent, and the older quantum theory is kept around because it works well at low speeds, for example in chemistry. Likewise the General Relativity theory works very well at astronomical distances, but even the GR theorists believe it will eventually be replaced with something that is valid at really short distances too.
Isn't time defined by the 2nd law of thermodynamics? The tendency to disorder is irreversible, so surely time must be linked to this, rather than any other aspect of Physics.
Well time isn't really a tangible thing physically, but it can be affected by physical things like gravity and velocity, electromagnatism, strong and weak nuclear force. Time is kind of hard to explain but we can witness it by the passing of events.
It's kind of like how the scientists are trying to find evidence of a graviton by it's absence after a particle collision. You won't actually see it, but you see evidence of it's existence.
  • · Replies 18 ·
  • · Replies 28 ·
High School The M paradox
  • · Replies 17 ·
