Electric Potential in Insulated U-Tube
The discussion focuses on calculating the electric potential at the center of curvature of a semicircular insulating rod with a uniform charge Q. The potential is derived using the formula V = (1/4πε₀)(Q/r), where r is the radius of the arc. The user, PK_Kermit, seeks clarification on how to incorporate the contributions from the two arms of the U-tube, as well as the significance of defining the potential to be zero at infinity. The principle of superposition is emphasized for summing the potentials from different components of the system.
  • Understanding of electric potential and charge distribution
  • Familiarity with the principle of superposition in electrostatics
  • Knowledge of calculus for integrating charge distributions
  • Basic concepts of electric fields and potentials in physics
  • Study the application of the principle of superposition in electrostatics
  • Learn about electric potential due to continuous charge distributions
  • Explore the derivation of electric potential from different geometries, such as rings and arcs
  • Investigate the implications of defining electric potential at infinity in electrostatic problems
Students and professionals in physics, particularly those focusing on electrostatics, electric potential calculations, and charge distributions. This discussion is beneficial for anyone looking to deepen their understanding of electric potential in complex geometries.
PK_Kermit
Hey, I have this question, and I'm having quite a bit of difficulty figuring it out.
"An insulating rod is bent into a semicircular arc of radius a, and a total electric charge Q is distributed uniformly along the rod. Calculate the potential at the center of curvature of the arc if the potential is assumed to be zero at infinity."
Which i see to be as so:
...|...o...|...<- the 'o' represents the center of curvature of
...\... /.........the arc...
....\.../...<-- this part is round.....
...u............
There is a similar question in my textbook, where tehy work out the potential at a point from a ring of charge. they use the equation:
V= (1/4[pi]E0) [integral] dq/r
[where dq would be infinitismal elements of charge about the ring]
for the ring, the r distance is always the same; so they remove r and integrate dq, to end with:
V= (1/4[pi]E0) ( Q / r )
now, my question is the U tube. I figure, since under the center of curvature lies a semicircle, maybe you could take half the potential found from the previous equation; i.e., for the curvature part, you could use:
0.5(1/4[pi]E0)( Q / r )
but, there is nothing in my textbook to say what I would do in terms of the extending arms of the U tube; as well, the question doesn't say anything about the length of the arms.
what is the significance of defining V to be zero at infinity, and where should I go from here?
Thanks,
PK_Kermit
The significance of defining the potential to be zero at infinity is that it allows you to calculate the potential at any given point using the principle of superposition. This means that you can break down the problem into parts, and sum up the resulting potentials at each part to get the total potential at the center of curvature. For this particular problem, you can calculate the potential at the center of curvature by breaking the problem into two parts: the potential due to the arc of the U-tube and the potential due to the two arms of the U-tube. The potential due to the arc can be calculated using the equation you provided (V = (1/4πε₀) (Q/r), with r being the radius of the arc and Q being the total charge). For the arms, you can use the same equation, but with the distance from the center of curvature to the end of the arm as the value for r. Once you've calculated the potential due to each part, you can add them together to get the total potential at the center of curvature.
  • · Replies 23 ·
  • · Replies 22 ·
