Calculating Tension in a Moving String: Is it Possible?
  • Thread starter Thread starter MrLobster
    String Tension
The discussion revolves around calculating the tension in a string connected to a hanging mass and an object on a flat surface, involving concepts from mechanics, specifically Newton's laws of motion and friction. Participants explore the relationships between tension, gravitational force, and frictional forces in a dynamic system.
  • Participants discuss applying Newton's second law to both the hanging mass and the object on the surface. Questions arise about the relationship between tension and acceleration, as well as how to account for forces acting on each mass. There is an exploration of the net forces involved and the implications of movement on tension.
The discussion is active, with participants offering insights into the application of Newton's laws and questioning the assumptions made about forces and accelerations. Some participants seek verification of their reasoning, indicating a collaborative effort to deepen understanding without reaching a definitive conclusion.
Participants are working within the constraints of a homework problem, discussing the need for specific values such as weights and coefficients of friction, and the implications of static versus kinetic friction in their calculations.
MrLobster
I understand that if a string is holding up a hanging mass then the magnitude of the tension in the string is mass * gravity.
The other end of the string is tied to an object on a flat surface (after being redirected by a frictionless pully). If the tension force is great enough to overcome static friction then the object, string, and mass will move. If I know all the relevant weights and coefficients of friction is there a way to calculate the magnitude of the tension in the string?
It must be less than mass * gravity because the mass is being pulled down.
It can't be the same as the frictional force slowing the object because the object is moving too.
If the hanging mass is in equilibrium, then you are correct.
Sure. Apply Newton's 2nd law to both masses.
If the hanging mass is accelerating, then you are correct: the upward force of the string must be less than the weight of the mass.
Again, if the system is accelerating you are correct. There must be a net force on each accelerating mass.
Do I need to know the tension in the string or the accelerations of the objects to do this? I was going to use the tension of the string to figure out the accelerations on the objects which should be equal since they are connected by a string.
Hmmm. Can you verify if I'm on the right track if I say:
The magnitude of the force on the mass: mass * gravity - magnitude of the frictional force on the object?
The accelerations for *both* the object and mass would be the force on the mass / mass?
Then I can calculate the force on the object and tension in the rope based on that start...
Generally the tension and the acceleration is what you are trying to find. By setting up Newton's 2nd law for the object and the hanging mass you'll get two equations with two unknowns: the tension and the acceleration.
No. The net force on the hanging mass is mg (downward) - tension force (upward). (Don't take shortcuts.)
The acceleration of any mass equals the net force on it divided by its mass. This is just Newton's 2nd law and its the key to solving these kinds of problems.
Do this. Identify all the forces acting on each mass. Then write down Newton's 2nd law for each mass:
[tex]\vec{F}_{net} = \Sigma \vec{F} = m \vec{a}[/tex]
If you do it right, you'll get two equations with two unknowns. Solve!
Thank you, this problem is clear to me now.
  • · Replies 19 ·
  • · Replies 17 ·
