Potential Energy Questions - I'm lost, help
The discussion revolves around potential energy concepts in physics, specifically focusing on a scenario involving a daredevil on a motorcycle and a system of masses connected by strings. Participants are exploring how to apply energy conservation principles to determine maximum height and speed in these contexts.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to understand the relationship between kinetic energy (KE) and potential energy (PE) and how to set up the problems using energy conservation. Questions about the use of vectors and the appropriate formulas for energy are raised, with some expressing confusion about the setup.
Some participants have provided insights into the conservation of mechanical energy and the relationship between KE and PE. There is an ongoing exploration of how to apply these concepts to the problems presented, with no explicit consensus reached yet.
Participants are navigating the constraints of the problems, including assumptions about frictionless surfaces and the effects of gravity. There is a mention of a diagram that may aid in visualizing the second problem, but details on its content are not provided.
kfink85
1. A daredevil on a motorcycle leaves the end of a ramp with a speed of 35 m/s. If his speed is 33 m/s when he reaches the peak of the path, what is the maximum height that he reaches? Ignore friction and air resistance.
I don't know how to approach this problem or set it up? Do I use vectors?
2. Three objects with masses m1 = 5.0 kg, m2 = 10 kg, and m3 = 15 kg, respectively, are attached by strings over frictionless pulleys. The horizontal surface is frictionless and the system is released from rest. Using energy concepts, find the speed of m3 after it moves down a distance of 4.0 m.
There is a diagram showing m2 in the middle of the table and m1 & m3 hanging off of opposite ends.
1. When he leaves the ramp he has KE only at the peak of his motion he has KE and PE. The total energy must remain constant.
What about the vectors? Do I set this up with X and Y components? I understand and agree with what you said but I'm lost.
Potential Energies are scalars (single numbers), not vectors.
You have to know the functional forms ("formulas"), but no component work.
(Most of us prefer Energy approaches, because they're MUCH easier to use!)
gravitational PE formula is m g h , so you need a vertical coordinate.
... KE formula is (1/2) m v^2
1. Since the daredevil is subjected to gravity alone we know that his total mechanical energy will be conserved. That is
[tex]E\ =\ K\ +\ U\ =\ constant[/tex]
or
[tex]E_{bottom}\ =\ E_{top}[/tex]
2. Here we have the conservation of mechanical energy of the system of masses again, since the only force doing work along the line of motion of the masses is gravity. since the masses are connected together they will all move with the same speed. Another way of expressing
is to say that the change in [itex]E[/itex] of the system at two different stages will be zero. That is
[tex]E_2\ -\ E_1\ =\ 0[/tex]
which can be written as
[tex](K_2+U_2)-(K_1+U_1)[/tex]
which after a little bit of arrangement comes to
[tex]\Delta K\ +\ \Delta U\ =\ 0[/tex]
that is the change in kinetic energy of the system plus the change in potential energy of the system will be zero. Or stated another way, what the system loses in potential energy it gains in kinetic energy or vice versa.
  • · Replies 21 ·
  • · Replies 21 ·
