| Thread Closed |
pH and Electrolysis |
Share Thread | Thread Tools |
| Mar10-06, 05:08 AM | #1 |
pH and Electrolysis
Hey all. It has been a while.
I have been interested in electrolysis for a while now and have been learning how different factors affect the reaction, e.g. distance of electrodes, concentration of solution, volume of solution electrolysed etc. However I am having problems finding research into how the pH should change during electrolysis (and not the affect the pH has on electrolysis). Because of this I have been researching it, practically, in chemistry (when the lab is free). I have been electrolysing copper (II) sulphate and testing the pH ever 5 minutes over a 45 minute period. However the results are not consistent and do not produce any sort of correlation. I was hoping someone could enlighten me to what should happen to the pH as any solution electrolyses. Cheers in advanced. Nice to see you all again. The Bob (2004 ©) |
| Mar10-06, 10:59 AM | #2 |
Recognitions:
while some reactions do produce a change in pH, others don't involve the acidity of the solution. The essence here is that, you've got to consider the equilibrium, if you're adding energy to produce the pH change, that is the energy affects the pH directly, than obviously you can model the situation to the experiment. If you are to produce any reactions which results in acid and base agents, so to speak, you'll have changes in pH. As for whether the direct electrical energy, somehow, alters the state of the autoprotolysis of water completely, upon reaching equilibrium, I'm not sure how that could work. If you were to change the temperature, the pH may change. Simply, a lot of factors affect the pH, but you should first consider the chemicals involved and then model the system.
| Mar10-06, 11:59 AM | #3 |
Thanks for that.
I have a solution of copper (II) sulphate, so adding electrons (from electricity) would give: [tex]Cu^{2+}_{(aq)} + SO_4^{2-}_{(aq)} + 2e^- \rightarrow Cu_{(s)} + SO_4^{2-}_{(aq)}[/tex] But from this, I cannot see any reason for the pH to change. It would only change once the concentration of copper was very low and the hydrogen in the water was reducded to hydrogen gases. Then the pH would change but before that I can see no reason for it not to. Am I right or on the wrong track? [I ask mainly because I found the pH to change over time but the equation would not suggest it at all]. Cheers The Bob (2004 ©) |
| Mar10-06, 03:46 PM | #4 |
Recognitions:
pH and Electrolysis
Copper can react as an acid, if you remember, although I'm not quite sure how efficient it'll be at this electronic state. How did the pH change with respect to time, did it increase/decrease, exponential, linear, no pattern....? Also, you've got to consider the activity pH, which should change, with the electrolyte composition.
| Mar11-06, 05:39 AM | #5 |
The Bob (2004 ©) |
| Mar11-06, 05:15 PM | #6 |
Recognitions:
You can't actually stop such reactions from occuring completely, so if the pH were to decrease, that is become more acidic, you would expect agents that are more or less acidic in the solution. The pH may have also changed slightly due to coprecipitation and perhaps the formation of hydroxide adducts, but none of these really affect the autoprotolysis equilibrium constant. You'll either need to identify an acidic agent, you can also account for the equilibrium change in pH in terms of activity pH. Really, I don't exactly know the details of this experiment, but you may also want to consider the existence of contaminants, silica glassware's affect on pH.
you should also take the temperature into account. If you were taking the pH with the pH electrode while working simultaneously with an electrolysis electrode in close context, this may have also affected the functioning of the pH electrode. |
| Mar11-06, 05:16 PM | #7 |
Admin
Copper reduction is only half of the processes taking part in the solution. What is the second half-reaction? Oxygen evolution? If so, here is answer to your question:
2H2O -> 4H+ + O2 + 4e- Best, Borek -- Chemical calculators at www.chembuddy.com equation balancer and stoichiometry calculator www.pH-meter.info |
| Mar12-06, 08:32 AM | #8 |
Cheers. The Bob (2004 ©) |
| Mar12-06, 09:08 AM | #9 |
Admin
| Mar12-06, 02:36 PM | #10 |
Recognitions:
Ok, my mistake, the copper ion should cause a basic solution, as possibly due to basic oxides, hydroxides, and hydrates. Thus removing copper, may have increased the acidity. I'm going not exactly certain about this though so I'm gonna research the exact details of the side reactions of copper in aqueous solutions.
We may also need to consider the effects of charge transfer transition of copper in a water complex, and its affect on the basicity if any. |
| Mar12-06, 02:46 PM | #11 |
Admin
What happens in this case is that on one electrode copper cation is removed from the solution while on the second electrode H+ are introduced, lowering pH. Once copper is removed you will be left with the solution of pure sulphuric acid, that's all. Best, Borek -- Chemical calculators at www.chembuddy.com equation balancer and stoichiometry calculator www.pH-meter.info |
| Mar12-06, 02:53 PM | #12 |
Recognitions:
you've made a typo there, are you saying that the presence of sulfate will decrease the acidity?
bob was trying to investigate the changes in pH, the changes in pH are influenced (whether to small or large degress) by the copper ions, you should investigate the original context of his query. |
| Mar12-06, 03:08 PM | #13 |
Admin
| Mar12-06, 03:56 PM | #14 |
Well... thank you both for your replies. Though I had my own theories (as you have seen and corrected), your input has really helped my understanding. Allow me to ensure I understand.
The solution should start neutral, ignoring the affects of hydrolysis. Once electrolysis starts, copper is obvisouly produced at the cathode. However oxygen is formed at the anode because it has a lower electrode (?) potential than sulphate ions. The reaction that forms the oxygen (2H2O -> 4H+ + O2 + 4e-), as Borek stated, means that the concentration of hydrogen ions increases and, thus, increases the pH. Now this is all good, we are left with sulphuric acid and copper on the cathode. But does the copper actually make any difference to the pH itself? I mean does the liberation of copper actually change the pH, assuming no oxygen was formed? I beleive it wouldn't but that is only based on common sense (and as I have learned, common sense is nothing in chemistry). Cheers for all your help so far. The Bob (2004 ©) |
| Mar12-06, 03:57 PM | #15 |
Sorry for the spelling mistakes in post 14 but my computer will not allow me to edit my post.
The Bob (2004 ©) |
| Mar12-06, 06:19 PM | #16 |
Admin
| Mar13-06, 03:32 PM | #17 |
Recognitions:
Bob, now that you have your probable causes, you'll need to establish them using some elaborate experiments. There's no sense in doing the experiments, and then asking the questions here to completely resolve your queries. It's most often the case that bringing up a subject as vague as this one will produce different opinions.
Try to specify the question that you have, so that you can work experimentally to arrive at a definite conclusion. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: pH and Electrolysis
| Electrolysis of water | Chemistry | 2 | ||
| Electrolysis | Advanced Physics Homework | 1 | ||
| electrolysis | General Physics | 0 | ||
| Using KF for electrolysis | Chemistry | 0 | ||
| Electrolysis. | Introductory Physics Homework | 4 | ||
