Solving Properties of Matter Problem: Steel Ring Expansion Force
  • Thread starter Thread starter Amith2006
    Matter Properties
The discussion centers on calculating the force exerted by a steel ring expanding on a wooden disc, given its radius (r), cross-sectional area (A), and Young's modulus (Y). The problem is approached using static equilibrium conditions, specifically the equation 2T sin(dθ/2) = N, where N represents the force between the ring and the cylinder. The approximation sin(dθ/2) ≈ dθ/2 is applied to simplify calculations, allowing for the determination of tension (T) based on Young's law for small elements of the ring.
  • Understanding of Young's modulus (Y) in material science
  • Knowledge of static equilibrium conditions in physics
  • Familiarity with calculus, specifically integration and small angle approximations
  • Basic concepts of mechanics related to forces and tensions
  • Study the application of Young's modulus in real-world materials
  • Learn about static equilibrium and its equations in mechanical systems
  • Explore small angle approximations and their uses in physics
  • Investigate the mechanics of tension in circular objects
Students and professionals in physics, mechanical engineering, and materials science who are dealing with problems related to material properties and mechanical forces.
Amith2006
Sir,
Please help me in solving this problem.
# A steel ring of radius r and cross sectional area A is fitted on to a wooden disc of radius R(R>r). If the Young’s modulus be Y, then what is the force with which the steel ring expands?
I just don’t have any idea on how to go about this problem.
Is that the exact wording of the question ?
It is extremely ambiguous, and as such, is bordering on nonsensical.
For a very small portion of the ring ([tex]dl=Rd \theta[/tex]) you have the static equilibrium condition:
[tex]2 T sin(\frac{d \theta}{2})=N[/tex]
where N is the force between the ring and the cylinder. Now you use
[tex]sin (\frac{d \theta}{2}) ~= \frac{d \theta}{2}[/tex]
and T from the Young law for the small element [tex]dl[/tex] (when it expands between [tex]dl_0=r d \theta[/tex] and [tex]dl=R d\theta[/tex]) and so on...
  • · Replies 30 ·
