Thread Closed
Accuracy and sensitivity...
Share Thread Thread Tools
Mar11-06, 02:46 PM   #1
Hi,
What exactly is the difference between accuracy and sensitivity as regards experimental apparatus?
Thanks.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Mar11-06, 02:55 PM   #2
Mentor
Usually people use the term precision, not sensitivity, but the difference is that precision means always getting the same results (repeatable, reliable), while accuracy means always getting the correct results. The dartboard analogy is the usual way to visualize it:
http://honolulu.hawaii.edu/distance/...5/accprec.html
Mar11-06, 07:42 PM   #3
"Sensitivity" can be seen as an ability to differentiate fluctuations in a given observed or tested event. "Accuracy" can be seen as the tolerance limits placed on "sensitivity"
Mar12-06, 02:00 PM   #4
Ich
Recognitions:
Quote by russ_watters
That sounds like repeatability. I know of the following expressions:
resolution - the minimum change the device will show
repeatability - as russ_watters said, the difference between two measurements of the same value
accuracy - the difference between the measured value and the real value
add: sensitivity - output signal times input signal, eg V/m when you measure length and the device gives you voltage.
Thread Closed
Thread Tools
Similar Threads for: Accuracy and sensitivity...
Thread Forum Replies
Chemical Sensitivity General Discussion 42
sensitivity expression Introductory Physics Homework 6
Sensitivity of a galvanometer Introductory Physics Homework 1
Sensitivity to CRT Televisions... ? General Discussion 8
Sensitivity/Accuracy General Physics 2
