Understanding Spin Stabilization in the M16 Rifle
  • Context: Undergrad
  • Thread starter Thread starter endlessace
    Spin
The discussion revolves around the concept of spin stabilization in the M16 rifle and the mechanics of rifling versus smooth bore guns. Participants explore the implications of rifling on projectile stability, accuracy, and velocity, while also touching on the aerodynamics of smooth bore projectiles.
  • One participant states that the M16 rifle's rifled barrel increases projectile stability through spin, comparing it to how a quarterback throws a football.
  • Another participant mentions Greenhill's Rule, which relates the twist rate of the barrel to the dimensions of the projectile for stabilization purposes.
  • It is noted that while rifling can enhance accuracy and range, it may also decrease muzzle velocity due to the interaction between the grooves and the projectile.
  • A participant introduces the concept of smooth bore guns, suggesting they achieve stability without rifling, and asks for clarification on how they function.
  • Another participant explains that smooth bore guns use projectiles with fins to maintain stability, drawing a comparison to gyroscopic effects related to angular momentum.
  • There is a mention of the historical context of smooth bore projectiles, specifically referencing "Sabo" rounds and their design.
Participants express differing views on the effects of rifling on muzzle velocity and projectile stability. While some agree on the benefits of rifling, others highlight the advantages of smooth bore designs, indicating that multiple competing views remain unresolved.
Participants discuss various assumptions about the mechanics of rifling and smooth bore guns, but there are limitations in the explanations provided, particularly regarding the mathematical relationships and specific conditions under which these principles apply.
endlessace
Hi all,
I'm a student at a comunity college in Maryland. I'm always interest in weaponry. As to my knowledge, the M16 rifle's barrel has a twist which mean to increase the velocity of the projectile. The projectile would come out the barrel spinning. Just like how quarterback throws a football. I believe that it's because of the "spin stabilized." Tell me if I'm right. Is there a formula for spin stabilized? (Velocity = ?) I need all the information I can get to write a research essay. SO PLEASE HELP.
Thank you
Minh,
Welcome to our little board! Yeah, that's the definition of a rifle -- the barrel is 'rifled,' or grooved, to spin the projectile. :)
The initial velocity has little to do with the rifling AFAIK. There is something called Greenhill's Rule, which gives you the level of twisting needed to stabilize a lead bullet -- it's like
(distance to go through one full revolution) = 150 * diameter^2 / length
where the diam&length are of the projectile.
Although rifling does increase range and accuracy, it actually decreases muzzle velocity. As the grooves on the inside of the barrel "grip" the projectile to spin it, they also slowe it down. Additionally, the grooves allow propellant expanding gases to escape around the projectile rather than pushing on it. However, these disadvantages are more than made up for in the greater stability of flight that rifling gives to the projectile. In addition to the gyroscopic effect, spinning the projectile also imparts a self-correcting feature to any minor aerodynamic flaws that may exist.
The great advantage of the military's new advance referred to as "smooth bore" guns is that they achieve this stability a flight without rifling.
How do these smooth bore guns work?
Better aerodynamics for the projectile, I think.
Tisk, tisk. Talking about guns. Guns kill people.
Anyway. The reason the bullut is more stable when it spins is the same reason why spinnging tops and gyroscopes stay upright.
It has to do with angular momentum so i assume your formula will have to use that.
Exactly. Smooth-bore guns are usually found on tanks, and they fire a projectile with fins (like a rocket). This projectile is encased in a shell that makes it form an air-tight seal with the inside of the gun barrell. Since these casings were originally made of wood, these projectiles were known as "Sabo" rounds, after the wooden shoes once worn in Holland. Once the projectile has cleared the end of the barrell, the wooden shell peels off, and the projectile continues onward, stabalised by its fins.
10K
12K
9K
