Show that this function is analytic
  • Thread starter Thread starter stunner5000pt
    Function
The discussion revolves around determining whether a given complex function is analytic. The function in question is expressed in terms of real variables x and y, and participants are exploring various methods to analyze its analyticity.
  • Participants discuss substituting x and y with expressions involving z and its conjugate to analyze the function. There are inquiries about whether this substitution would simplify the process or if there are more straightforward methods available. Some suggest checking the Cauchy-Riemann equations as a potential approach.
Multiple methods are being considered, including the use of substitutions and the Cauchy-Riemann equations. Participants are actively questioning the effectiveness of these approaches and exploring the implications of the function's domain on its analyticity.
There is mention of the complexity of the function and the possibility that it may not be analytic in certain domains, raising questions about the conditions under which the function is defined.
stunner5000pt
[tex]\left( x + \frac{x}{x^2 + y^2} \right) + i \left( y - \frac{y}{x^2 + y^2} \right)[/tex]
now... would i substitute [tex]x = \frac{z + \overline{z}}{2}[/tex]
and
[tex]y = \frac{z - \overline{z}}{2}[/tex]
and then see if z or z bar appear exlicitly in the function??
Would that solve it??
Is there an easier way? A less Messy way?
If I recall correctly, a function is analytic if it is differentiable and if it satisfies the Cauchy-Riemann equations, perhaps you should check those?
is there another way of doing it... perhaps using the substitutions i suggested above and then checking the domain of the function?
Using the Cauchy-Riemann equations is probably the easier way.
and
Your equation for y should be over 2i not just 2.
There are complex functions whose domain is C but are nowhere analytic.
  • · Replies 17 ·
