Calculating Distance of a Planet from its Sun for Energy Determination
  • Context: Undergrad
  • Thread starter Thread starter Blissfulpain
    Ellipse Radius
The discussion revolves around calculating the distance of a planet from its sun in order to determine the energy it receives over a year. Participants explore the mathematical modeling of planetary orbits, specifically focusing on elliptical orbits and the equations governing them.
  • One participant expresses uncertainty about how to model a planet's orbit and calculate its distance from the sun at different times of the year.
  • Another participant questions the definition of a "year" in the context of orbital mechanics, suggesting that it may lead to circular reasoning.
  • There is a discussion about the equation of an ellipse and its application to determine distances, with references to maximum and minimum distances from the sun.
  • One participant mentions that planets do not maintain a constant speed in their orbits, which complicates the calculations.
  • Another participant proposes using polar coordinates for orbital mechanics, providing a specific equation for an ellipse in that context.
  • There is a suggestion that understanding the relationship between the major and minor axes of an ellipse is crucial for determining distances at various points in the orbit.
  • One participant expresses a desire for a general equation to model any planet orbiting any star, indicating a need for clarity on how to rearrange the ellipse equation to find distances based on angles.
  • Another participant challenges the idea that orbital speed is not important, indicating a disagreement on this point.
Participants do not reach a consensus on the importance of orbital speed in calculations, and there are multiple competing views on how to approach the modeling of planetary orbits and the associated calculations.
Participants express uncertainty about the application of the ellipse equation and the relationship between time and position in an orbit. There are unresolved questions about how to determine distances at specific angles and the implications of using different coordinate systems.
Blissfulpain
"Radius" of an Ellipse
a couple things I'm trying to fit together.
First: a planet orbits a sun (positioned at one focus) at an certain speed. At any given time of year it will be at that same spot year after year... i have little clue how to make that work or solve for it.
Second: i need to take that point and deterimine what it's distance is from the sun.
Note: i am a high school graduate, but did only average in mathematics and conics was most certainly not a strong point, however i have a bascic understanding.
Purpose: i need to determine the distance a planet is from it's sun for a 1 year cycle to determine the amount of energy it will receives on any given day.
thx
Mathematics news on Phys.org
That only works if your definition of 'year' is the time it takes for the planet to go around the sun once. But that's circular reasoning and not very interesting...
You might want to study http://home.cvc.org/science/kepler.htm
Make what work? Solve for what? What exactly are you trying to do? Do you know the equation for the ellipse? Do you have it in terms of time?
If you have the equation for the ellipse in a coordinate system with the sun at the origin it's easy.
If you know the maximum and minimum distances from the sun to the planet, then you can set it up the equation of the ellipse:
x2/a2+ y2/b2= 1.
You're not completely out of the woods after you have done that. You still need to associate each point with time. You say "at a constant speed". You do understand that planets do not maintain a constant speed as they orbit the sun? (They move faster as the get closer to the sun, slower as they move away.)
well, i suppose speed is less relavent... hmm. uh well, ok i'll try to explain.
i want to be able to model any planet orbitting any star at any distance. so i need to be able to have a general equation and have numbers plug into that and then get a nice answer.
first thing i need to figure out is how do i determine the distance the planet is from a star if i know it's major and minor axis.
i sort of re-thought the orbital speed and that's less important, because if i use a cartesian plane then it will move around the star focus at X-degrees per day kinda thing i guess.. and that would stay constant.. so orbital speed is not important really.
i know the quation of an ellipse is (a^2/x^2)+(b^2/y^2)=1 but i don't really understand how to use that or re-arrange it to determine any sort of distance equation (or find a point at a certain time of year or in my case a certain angle in relation to the sun focus).
so i guess what I'm saying is that if the planet is at 180 degrees, then it's on the left side of the major axis (of a horizontal ellipse), and is lined up with both foci. i don't know how to figure out how close the star is though (if the star is the left focus). nor do i know how to determine the distance at any other point in the orbit (or degree compared to the left focus, where the right side of the x-axis would be 0 degrees and the left side would be 180)...
i hope i didn't confuse anyone more.. i just don't have an equation, so there are no specific numbers. if you must, you can use an ellipse with a minpr axis of 3 and a mojor of 4, the star is the left focus of a horizontal ellipse. it would be much appreciated if you could give me any sort of general equation(s) to find the distance the planet is from the sun at anypoint of the ellipse and also determine that point based on any sort or method of a "time of year" scale
Generally, "orbital mechanics" is done in polar coordinates with the origin at the sun. In polar coordinates the equation of an ellipse (in fact, any conic section) is
r2= a2(1- e2)/(1- e2cos2θ)
where (a,0) is the point where the orbit crosses the positive x-axis (θ= 0) and e is the eccentricity of the orbit.
ok thx, i'll look up stuff on orbital mechanics... i'll ask if i have more questions. thnks for the help
That's incorrect too...
  • · Replies 0 ·
  • · Replies 17 ·
